diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Lowest noise levels - Click HERE for Original Thread
difi
How are the noise (not distortion) levels of GC's compared to the best non-GC amps?
I've got a high-sensitivity system (104dB/1W) w/active xovers and, although it'd be nice to simplify my amp stack w/some GC's, the absolute lowest noise floor is my ultimate goal.
Nuuk
With the proviso that they must be built propely (which applies to all audio circuits) I would say that the noise floor will be no higher than, and probably lower than other types of amplifier.
I have 95 db sensitivity speakers in open baffles and can hear absolutely nothing even with my ear just inches from the cone.
As you say, the Gainclones and active speakers were just made for each other! ;)
mikelm
That's strange...
my gainclones gave audible hiss with my ear next to the tweeter.
my JLH simple class A is completely silent.
mike
P.S. Nick, thanks for your reply to me earlier as you can see I finally made it...:)
johnferrier
Regarding noise, I believe that is one area that discrete circuitry holds the edge. For example, Erno Borbely's Super Buffer operates about 260nV 20-30khz and the new ultra-low noise AD8671 will (I believe) operate at >300nV 20-30khz. Super Buffer uses 2sk170/2sj74 (0.95nV/hz sqrt) and the AD8671 (2.8nV/hz sqrt).
JF
Page generated in 0.021174907684326 seconds with 17 queries,
spending 0.00803280 doing MySQL queries and 0.01314211 doing PHP things.
Please support our sponsor.
