diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
line level converter - Click HERE for Original Thread
b<ben>n
hi im thinking of making a small sub using a venom 8" from jaycar
the mighty midget amp
http://www.dse.com.au/cgi-bin/dse.s...duct/View/K5401
and a Sub-Bass Processor
http://www.dse.com.au/cgi-bin/dse.s...duct/View/K5403
but i need help finding something that can convert the speaker output from my main amp to a line level signal for the sub amp.
and also will i need a Xover.
thanks
ben_squire
rabbitz
I think it's the same kit as the Jaycar KA-1814 and has the items you want.
It will do speaker level as well as line level and low pass filter is built in so you don't need a separate crossover.
Has High-Pass (20Hz) filter, Low-Pass (40Hz-200Hz variable), Gain control ±12dB, Equaliser ±12dB with 30Hz to 190Hz centre frequency. Needs a +/- 15V power supply.
Page generated in 0.016906976699829 seconds with 17 queries,
spending 0.00677848 doing MySQL queries and 0.01012850 doing PHP things.
Please support our sponsor.
