diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
GC 0,22R output resistor - Click HERE for Original Thread
2Bak
In one of my Gainclones I use Caddocks MP915 0,22R in output with this schematics: http://home.comcast.net/~greggbaker/invertedLM3875.gif
Those Caddocks are quite expensive. In another of my Gainclones I used an inexpensive 0,2R power resistor, and I'm rebuilding this one, so maybe I should use the opportunity to switch to Caddocks while I'm at it, however I'm not sure I could hear any difference compared to the Caddocks....
My question is: Does the quality of the 0,22R resistor have any importance on the sound quality of this amp, at all..?
I am gonna use this 0,22r, and I won't leave it out as many have suggested :angel:
Jan
leadbelly
I do not understand why you would post this. You are in a privileged position of having a GC built one way and a GC built the other way. Don't you trust your own ears? Did I miss something?
BrianGT
Indeed, try listening to both configurations yourself, and I also recommend trying it without any resister in series with the output.
Brian
till
the best you can do for your reputation on diyaudio.com is to post the GC sound much better with the expensive resistor, and you will never go back and use cheap resistors anymore. You even canīt understand how you ever listened to any music before with pleasure.
I personally donīt belive you or anyone human is able to hear any difference between resistors, but oops, it was a big mistake of mine to admit this here in public.
2Bak
At the moment with my speakers and all my other gear, I cannot hear any difference. Perhaps If I tried those two configurations on some other gear I could tell a difference, who knows.
Music is what matters for me, not components. And I wonder if I was a fool spending that money on the Caddocks in the first place ;-)
Being hooked on DIY, sometimes I find myself loosing my ground control, and presuming expensier is better, instead of using my time on listening to music, that's for sure.
I trust my ears and my feelings when I listen to good music. I'm not sure I trust my ears when I have to audition audio gear.
But most importantly: I'm happy with my DIY amps and that's what counts for me, and I believe I've found in the Gainclone an amplifier I can live with for many years.
Yes Leadbelly, this posting was a waste of time.
Peter Daniel
Don't use any resistor, you probably don't need it.
Peter Daniel
quote:
Maybe you should read this?
http://www.audioasylum.com/forums/h...ages/15679.html
till
ok, you are on the right way, a little reflexion like that is something a lot people on this board could need...
2Bak
quote:
Why, Peter...?
What's it used for, by the way?
/Jan
sreten
Having an 0.22R allows you to omit the output inductor.
Though adding the missing Zobel seems a good idea to me.
:) sreten.
Peter Daniel
I've seen some people experiencing problems with wrong choice of speaker wires (mostly distortions at high frequencies). Zobel didn't help at all, changing wires did.;)
In all the amps I built (always without resistor), the resistor was not needed.
Arius
Do not use a 0.22R series resistor at the output by itself. This resistor is only meant to be used in conjunction with an output inductor.
1) Output inductor is used to to provide a stable load when driving highly capacitative loads, e.g. long speaker wires.
2) Series resistor (paralled with the inductor) is to damp the LC combination.
Zobel network is for a totally different purpose. It's to provide a load at very high frequencies (where the speaker is no longer 8R).
For highly stable amplifiers like these (if used correctly), output inductor/resistor combo is not needed. Neither is Zobel.
Upupa Epops
These resistor is mandarory only in case, if you can connect two channel in parallel mode. In another cases you may let it. But remember on this - if you connect two amps in parallel without this resistors, it will be deadline for both.
tbla
and by that you don't mean bi-amping but having several chips in parallel sharring the same load....right.....?
Upupa Epops
Right :cool: .
2Bak
I just wonder why the all schematics I've seen on
http://www.ampchipdiy.com/phpBB2/viewforum.php?f=2
includes this resistor...?
Also the most updated one http://ampchipdiy.com/invertedLM3875_r2_1.gif
:scratch:
But perhaps I should ask this question on the ampchipdiy.com forum itself...
I guess quite a few who have build this variation of the IGC have included this resistor. At least those not so experienced DIY builders like me, who stick to the book to be on the safe side ;)
If one uses this resistor, and since it's more a part of the speaker system than the GC circuit, a good non-inductive resistor must be an advantage then, and maybe my Caddocks was not such a bad pick after all...
/Jan
Page generated in 0.040070056915283 seconds with 17 queries,
spending 0.00784636 doing MySQL queries and 0.03222370 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
