diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Got my Zap pulse 2.2SE modul today - Click HERE for Original Thread
ryssen
Does anyone have a schema for this one,just for fun to see how itīs constructed.
dirkie007
Maybe this can help...
Link
pburke
quote:
you just got one module? ;)
I'm very interested in hearing from you and others how this amp works out. Once I can afford it, wamt to build two 2.2SE stereo amps and an active crossover to biamp my speakers. I'd like to hear about experiences with alternate power supply designs, bigger transformers than recommended, etc - just to do it right the first time aorund.
Peter
ryssen
I am going to use it to drive a subwoofer,havent tried it yet.
bambadoo
Dont think you will se a scheme of the zappulse modules.
ryssen
No.....Just asked incase someone had one.
michaelab
quote:
See this thread :)
I'm using an 800VA transformer instead of the 500VA they recommend. Of course I don't know if it makes any sonic difference but I think it sounds great :)
Michael.
ryssen
Nice amp!!!
1.How much uF are you using per module in the power supply.
2.Is the inductor hanging in the air.
3.Does the modules get hot under heavy operations,(high soundpressaure).
michaelab
I'm using the LC Audio Virtual 4 pole PSU which has 10x10000uF in total. I don't really understand the principle of the V4P "network" (some say it's a load of bull) but I don't think you can just divide that by 2 to get 50000uF.
I think it's more like 40000uF per channel.
Yes, the inductor is just hanging in the air.
The modules get warm but not hot. The base of the module is a thick plate of aluminium to which the MOSFETs are screwed and I have that just bolted to the bottom plate of my amp case and that's enough heatsinking.
Michael.
Page generated in 0.032983064651489 seconds with 17 queries,
spending 0.00858092 doing MySQL queries and 0.02440214 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
Please support our sponsor.
