diyAudio.com diyAudio Forums Archive > Top > Source > Digital
CDM1 motor in a CDM4/19 ??? - Click HERE for Original Thread
Lyra
Is it possible pick out the spindle motor of a defekt CDM1 mechanism, and mount it in a CDM4/19 ?
I have read some statements claiming one of the reason the CDM1 is superior the CDM4 is the fact that the CDM1 uses a brushless motor, and CDM4/19 is not....
.....so do it fit, and is it possible just to replace the motor, and leave the rest as is ??????
PS: Maybe a stupid question, but I have newer seen a CDM1 close up so it is impossible for me to know much about it.
Lyra
Magura
If youre right about the brushless and not brushless, i can tell you as much as you need the motor control from the cdm 1 for running the motor from the cdm1.
Those dont mix and match.
Magura:)
Page generated in 0.014884948730469 seconds with 16 queries,
spending 0.00728106 doing MySQL queries and 0.00760388 doing PHP things.
