diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Determining T/S Specs of a sub - Click HERE for Original Thread
nuttinbutSQ
Is it possible to determin the T/S Specifications of a sub woofer, if you can, how do I go about doing it. The only specs I know is its impedance, voice coil size, and speaker size. Could someone please explain the process or point me to a link where I may gain the how to knowledge.
Thanks,
D.
red
I am a newbie myself but using google I found this and I hope it will help you...
http://sound.westhost.com/tsp.htm
http://www.epanorama.net/documents/...parameters.html
And check out the older threads because there is a spreadsheet for determining the ts parameters
Page generated in 0.22515511512756 seconds with 17 queries,
spending 0.18166137 doing MySQL queries and 0.04349375 doing PHP things.
