| Andre Baptiste |
| Hey folks...i was jus wondering when building a subwoofer right......you all use jus glue or both glue and screws to put the box together.......thanks...... |
| coolkhoa |
| I'd say, for a subwoofer, go with glue and screws for stronger joints. |
| Andre Baptiste |
| Ammmm okay thanks but how do you prevent the wood from cracking??? |
| thomas997 |
Pre drill the screw holes?
You also might want to put some bracing in by simply glueing in some wood blocks in the corners. |
| roddyama |
Hi Andre,
Good to see you're still at it.:up:
If you are using MDF and plan on covering it, you can make the joint like below. |
