diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
S video color loss to projector from sat receiver - Click HERE for Original Thread
cyberian
I just bought a Proxima dp 5900 and I am running a 31ft s video with an a/b switch box from my dvd player and satellite receiver and the picture and colors are fine from the dvd player but when I switch to sat receiver the colors are all red and I have to turn the color all the way down to watch it. I have tried all the adjustments and wanted to know if an s video amp would help and why is the dvd color fine through the same cable ? Any ideas ? Thanks
faithblinded
Try using a diff, high quality cable in between the Satellite reciever and your A/B switch box.
Also, try plugging your sat receiver directly into the tv to see what happens. This will help u figure out whether its the switch, cable, or the receiver itself. Hope that helps.
cyberian
Thanks , I ran a component cable and it fixed the problem for the receiver to the projector.
Page generated in 0.016779899597168 seconds with 16 queries,
spending 0.00642490 doing MySQL queries and 0.01035500 doing PHP things.
Copyright ©1999-2009 diyAudio.com
