diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Questions re: digital grounding - Click HERE for Original Thread
echo
Hello all,
I have been working for some time on my first DAC project (CS8420, SM5847 (if I can find one!), PCM1704), and am currently working on the PCB design. The PCB will be 2 layers, and am wondering what the proper method is for grounding the digital and analog sections; it seems the more I try to learn about this subject, the more different opinions I find, and the more confused I become...
I know that most mixed signal designs split the digital and analog ground planes to avoid noise from entering the analog section, connecting at only one point, often under the dac or adc chip. I have also read that the dac chip should be considered an analog part and should rest entirely on the analog ground plane.
An article I found on the Analog Devices web site:
http://www.planetee.com/planetee/se...t?ArticleID=593
suggests that the two ground planes should be "kept separate all the way back to a common system 'star' ground, generally located at the power supplies."
This is the same technique used by Erland Unruh in an article a couple years back in Audio Electronics magazine.
However, I have also been re-reading the article posted on Marc Heiligers DAC page:
http://members.chello.nl/~m.heijlig...html/dactop.htm
by Guido Tent, an EMC engineer at Philips who suggests NOT splitting the ground plane, but keeping it closed:
http://members.chello.nl/~m.heijlig..._decoupling.pdf
He states that (with proper decoupling of all chips and the use of lossy ferrite beads on all power feeds) splitting the ground plane creates a huge loop which "leads to high emmision, and a higher chance of inter-system pollution."
I had also considered using isolators such as the Burr Brown ISO150's (as used by Parts Connection on the DAC3.1) to isolate separate digital and analog groundplanes. Would this help address the poblem, or would these devices just be another source for noise and jitter?
So what should I do? I am using lossy ferrites and SMD polymer electrolytics for local decoupling for each chip.
Any feedback, or links to articles on this subject would be greatly appreciated.
Thanks!
Mark
kiwi_abroad
I'm afraid I don't have any answers for you, but I know exactly how you feel. The more research you do, the more confused you get, as lots of possible solutions and 'best techniques' seem to be conflicting and at complete odds with one another, and lead to impossible PCB layout problems.
In my last DAC, I eventually just bit the bullet and implemented a split groundplane, joined in the middle, with completely seperate power supplies (4 x 12v Sealed Lead Acid Batteries for the analog stage) and lots of ferrites and SMD decoupling caps and components. It sounded fine.
If I ever get around to building another DAC, I'll isolate the thing completly by using a transformer coupled digital input, ISO150's between the digital and DAC/Analog stage, and seperate isolated power supplies again. A bit more physical seperation between the two stages wouldn't go amiss either (Oh no, now you've got me thinking...)
I think the only way to be certain something works or doesn't work is to build a prototype, measure it and then modify and measure again, which is outside the abilities of most DIYers to do it accurately. We're not interested in obtaining international EMI certification, we only want to make sure it doesn't interfere with our music.
Cheers, Adrian
HarryHaller
Here is a good place to start research. I highly recomend his book also. www.sigcon.com
H.H.
Jocko Homo
Follow Analog Devices advice. The subtle problem with a ground palne is that it can act like an antenna. You need to bypass all wires in/out of the device better.
Don't split the ground planes too far apart: it will cause a larger loop for the currents to circulate.
Can't get the NPC chip still? Let me know.
Jocko
echo
Thanks for the feedback!
The sigcon site is great- most of it is way over my head, but I have already found some useful information.
I suppose I will go for the split ground plane like Adrian, bridging the two sections on the board. I'm thinking that using an entirely separate power supply for the analog section with separate power transformer might be a good idea, so that the only ground connection between analog and digital section would occour at the ground bridge on the board. Or would this be coutrerproductive? (I still want to think of digital signals like analog signals, although I know they behave quite differently) Could this Increase system noise? Should power supply grounds be tied together before they enter the board?
Or maybe the ISO150 isolators are the best solution. Anyone else have any experience with these?
Lastly, what kind of bypassing do you recommend Jocko? (and look for an email regarding that impossible to find 5847 chip)
Mark
capslock
If you place the receiver circuitry and maybe even the filter on the digital plane, include 100-300 R series resistors in the signal line and place all of the DAC on the analog plane, the separate plane approach might be OK. You will have some loss of noise margin on the digital signals if the two grounds are connected with too much inductance in between. This is probably not going to hurt signal transmission but may screw up the timing (jitter!) which is only critical if the clock is not generated in or right next to the DAC chip.
Do not by any means connect the digital ground and supply pins of the DAC to the digital network! Any noise between the two ground planes will end up inside the DAC substrate.
Eric
Jocko Homo
Have you looked at the price of those isolator thingies??? I suspect not. You are on the right track......keep going. Bypassing: 0.1 uF caps everywhere you can shove them, the big electrolytics don't seem to be that critical. I've built ones with nothing, and others with big caps everywhere. Personal preference works here.
Jocko
jwb
I don't think the ISO150 is worth it. In fact,
it is probably worse than having a little noise
on the ground plane. You will need two
IS0150s for a stereo DAC: one for the clocks
and one for each data line. Unfortunately,
the worst-case interdevice time delay is
quite high, so you might wind up with more
time domain problems with your digital
signal than you would other wise have.
That is to say, your clocks and your data
might not arrive together.
Keep it simple: decouple each IC power pin
with a big cap and a fast cap, liberally
employ ferrite beads. You'll have as clean
power and ground planes as you can hope
for in a 2-layer PCB layout.
Havoc
Stay away from the opto's. I got a board here with an opto coupled digi-analog split. Nothing but trouble concerning noise/hum. Both grounds are completely split, but what do you do with the cables/connectors going out? The timing problem with opto's can be solved by using a pll and VCXO on the analog side driving SH circuit. Only a single Fs then unless you switch VCXO's.
I would go with the single plane. Once your circuit is done, fill both sides with copper and lay via's where you can connecting both planes together. Make sure to bridge any important gap in the gnd-copper and try to have gnd under each Vcc trace.
Only 0.02
tiroth
Hopefully I can at least temporarily bring this thread back to life. Some very useful discussion here.
With my current design, I've been leaning towards the "moat" paradigm suggested by Jocko and endorsed by Dr. Johnson. I've got a couple of issues, though:
(1) As Havoc noted, in any DAC design we'll have a non-isolated connection for the audio output. Won't this open up the analog "island" to circulating currents due to the additional inter-ground connection(s)?
(2) In the case of multiple DAC ICs, it is no longer possible for the chips to straddle the "drawbridge".
-Next move is to lay the DACs on the analog ground and bring the signals across the drawbridge. Crosstalk aside, won't this create significant issues by increasing the return path of the digital input?
-Alternatively, create an "island" for each DAC, allowing preservation of the original layout and ground return paths. Is this a problem?
A single plane certainly seems like the easy way out of this dilemma, but I have grave doubts of its ability to provide the necessary isolation.
To stir things up even more, why isn't there any discussion of ground topologies other than ground fill? Although I am relatively ignorant, I was under the impression that planar fill was (often) not encouraged for some of these reasons, as well as radiation and RFI pickup.
HarryHaller
Go for the solid ground plane And good decoupling for the digital power pins like 0.1uF SMD ceramics. This is a very complicated subject even among RFI and digital engineers. Getting the noise coupled into a good ground plane will help minimize to need to isolate it from analog circuitry. Dr. Johnson's book and the www.sigcon.com website will give you the most insight into this subject as well as ap notes on mixed signal design at the major semiconductor sites like www.analog.com I spent two years working on a two layer digital analog telecom line card and a large part of that was on grounding and decoupling.
H.H.
Jocko Homo
Yes, indeed..........
But that is why you bypass all connections in/out of the enclosure.
Jocko
HarryHaller
You hear the most outrageous lies about it. Half-baked goggle-boxed do-gooders telling everybody it’s bad for you. Pernicious nonsense! Don't forget to seal the trunk of your'64 Chevy Malibu!
H.H. (Hot and Hazardous Helping hand)
Harry Dean Haller
sonnya
You could use the split thing to some level.
Example :
Your PLL for the DIR1701/1703. You have 3 pins : AVDD (pin 24),AGND (pin 23) and FILT(pin 22).
Your DGND is placed on (pin 6).
Then look at the image. It is not split up that much. Normaly you would take you AVDD from your DVDD through a filter (ferritbead, RC filter ... )
Sonny
PS : I forgot to say that this is a way of prevent digital current loops flow through the PLL filter wich is your ciruit needed to make a stable and jitter "free" clock. This is not possible when you do not make such thing to you PCB design.
jackinnj
Read the notes at www.analog.com on the AD8307 logarithmic converter. If you don't ground this baby correctly you can have a very nice wide band receiver (with great dynamic range!). I liked the comment on www.sigcon with respect to fixing a groundplane problem -- if you are succesful this becomes your job description. I also read on one of the analog sites the tale of finding emi problems by using an inexpensive (aka very cheap) a.m. radio and passing it over the circuit to find the offending elements.
tiroth
An article which addresses multiple ICs requiring quiet grounds:
http://www.sigcon.com/articles/edn/multipleadc.htm
I am planning on going with the "multiple moat" approach and use differential outputs, avoiding any reference to chassis (or external) ground.
Does this change your single-ground recommendation Harry?
Your bypassing note is well taken Jocko.
Jocko Homo
Did a CD player mod......about 12 years ago with a ground plane. Radiated like mad. Mainly from the analog output jacks.
Jocko
HarryHaller
A ground plane is the most effective grounding schema for digital circuits in terms of low noise coupling and low EMI. Nothing I have ever read of measured has shown me any reason to believe otherwise. I did EMI reduction as part of my last three jobs and gave a lecture to 150 people on the subject. For a list of good books:
http://www.emiguru.com/bibliog.htm
The following are the best that I have read and are the standard references that I have seen on many engineers bookshelves.
"EMC and the Printed Circuit Board," Mark Montrose, IEEE Press, 1999
"High-Speed Digital Design," Howard W Johnson and Martin Graham, PTR Prentice Hall, 1993
"Introduction to Electromagnetic Compatibility," Clayton Paul, John Wiley & Sons, 1992.
"Noise Reduction Techniques in Electronic Systems," Henry W. Ott, John Wiley & Sons, 1988
H.H.
Jocko Homo
On the CD player mod, it was necessary to put a cap (few hundred pF) from the output to the ground on the RCA, then put a 0.1 uF from the RCA ground to the chassis ground. With short leads. EMI gone. The analog ground leads acted like a good antenna.
Jocko
kenev
I' m in the process of designing a PCB (double sided) for a TDA1541 non-oversampling DAC, which will be driven directly from the I2S output of my CD-PRO2 drive. Actually, the DAC will use two TDA1541 dac chips in parallel.
Reading the posts in this thread, the following question arose: should I use a single or dual (A + D) ground plane? The board will not include other chips except the two TDA1541 dac chips. According to the posts, the dac chip should be considered as analog part and should rest entirely on the analog ground plane. But, on the other hand, this chip has already two seperate ground pins, one analog and one digital ground. If the designer of the chip chose to have two different ground pins, why should I consider them as a single ground point?
So,which way to go, single or double ground plane?
tiroth
Generally in the case of multiple ground pins they are connected in the substrate. In this case connecting the pins to different grounds (=> different inductances with respect to power supply ground) will result in circulating ground currents within the substrate. Not good.
The manufacturer is probably the best source for information about the topology of an IC.
guido
Kenev,
Working on double sided PCB with 2 TDA1541's aswell.
If you have space for one '74 flipflop, one 4517 shift
register and one 20V8 GAL, the TDA's will be split into
left and right (one for left, the other for right channel -
output differential as choice).
I am now working on a clock in the DAC and feeding it back to
the player (FIFO register to avoid sync problems).
All on one Eurocard sized board (but not the clock, powersupply
or analogue output).
So i also have to figure out how to do the grounding.
What i did now:
AGND and DGND of the TDA connected under the DAC.
The name of the pin says to what they are connected on the inside,
not what they should be connected to on the outside. From an old
analogue devices application note (dont know if it is the one
from the start of this post, link doesn't work. Have a papercopy)
i could find that AGND and DGND should be connected to the analogue
groundplane. The PCM63 datasheets also says that explicitly (Elektor
did not read this when they made their first DAC...).
filtercaps and analogue powersupply (was it the -15V,
cant remember right now) connected to AGND pin.
GND of the digital logic connected to DGND on the board.
DGND powersupplies connected to the DGND pin.
I plan to use separate transformers (trannie's, my english fails here) for
each powersupply to avoid having the grounds connected at the powersupplie aswell.
I have decoupling with one small cap at all digital logic ic's and an oscon with two smd caps
(like thorstens DAC) on the TDA powersupply and the clock divider IC).
No resistors in the signal lines and no ferrite beads now, should i change this ??
There are two separate groundplanes on the board on the toplayer, currently connected to nothing.
I don't know where to connect them to gnd yet, maybe at the powersupply connectors ?
All of this results, i think in a short returnpath for the data,ws and clock signal from the digital
part back to the logic. Also short returnpath for the analogue signals to AGND, without going over the
digital GND lines (output, supply and filtercaps also have different tracks back to AGND pins).
Then one track between DGND and AGND per DAC.
The DAC GND are connected together on the border of the analogue (DAC) and digital part, close to the
digital logic (so they don't share much track there). Now my problem (?) I create a huge GND loop
on the analogue side of things. From this common gnd point to the DGND pin to the AGND pin of a DAC, then
to the output post to the output stage, from there or even in the preamp back to the output post of
the other DAC, to AGND, DGND and then back to the common point. Bad idea ???
I was figuring there should not much currents going between the analogue and digital GND pins of the DAC
and between them. But maybe i am totally wrong !!! Or can i get away with it, by using audio transformers
in the output stage.
Sorry for the long post, hope for some reply from the experts (i'm not, i am called Guido and also from Holland.
But i am not Guido Tent :->).
To give you some idea's, i posted the first version of the PCB design. Schematics will follow if it all
works..
Greetings,
Guido
PS, made a PCB for a DSP + ADC way back in school. It worked, but the DSP quit the with the ADC port
(serial port to ADC) now and then. We bought a second DSP before we figured out the GND plane was ****.
It was fixed with a wire from ADC GND to DSP GND (creating a nice loop...). But then it never quit.
Bad PCB design.
guido
Some comments after re-reading..
-statement on PCM63 DAC gnd was only as example.
-elektor split agnd and dgnd with resistor between agnd and dgnd pin on their PCM63 DAC..
-is a trannie a transformer? Again, my enligh fails
-when you look at the top layer (with the gnd planes), the two tracks crossing the separation on the board are the gnd tracks from DACs back to logic. Also you can see the smd caps on the dgnd pins and the track to the DGND pin of the dac. The IC in the top of the digital part is the clock divider, there the GND from the DAC's are connected to the logic part. Just under it, the GND's of the DAC's are connected.
-On the bottom side, the connection between DGND and AGND is the track under the DAC. On the AGND some kind of "star" towards the output, supply and filter caps.
-I still have to ajust pad sizes etc.
Guido
Guido Tent
dear all,
I am happy to note all interest on layout and ground planes and related suff.
Wrt multple ground pins: They should see as much as possible (!) the same potential, as internal circuits relate to these, and signals go from analog to digital domain at least once (internally that is).
Decoupling caps, being supply, filter or internal reference, should ofcourse be connected to the right ground (or reference) pin. Very often a star like strucure from that pin to relevant decoupling caps is proposed, to avoid voltage buildup across the plane.
Ofcourse all ground pins are connected to the same plane.
While RF emissions are not our (DIY) highest concern, my experience is that pushing them down, sound quality increases.
I wrote an article a while ago, on layout and stuff. It can be found here:
enjoy
Guido Tent
tiroth
Guido, just a warning, that board looks like slot antennae nightmare! Digital lines should be everywhere above (below) a solid ground plane. The return is going to mirror the digital line on the plane. In addition to high radiated EMI, there are going to be large circulating ground currents because there is not a low-inductance return from AGND. One solution would be a bridge across the moat, and route all traces under it. This would require rethinking your analog grounding scheme though. (It is a little hard to tell exactly what is going on with your board w/o any descriptors though) Even then, your top-ground plane looks like it has slot antenna potential with those traces cutting through it, but I do not have the expertise to address that. Jocko designed what looks to be a nice board with top-ground for the analog section, so maybe take a look at that and talk to him. I don't think he routed anything significant on the ground layer.
I would recommend taking a look at some of the articles I've referenced previously. In particular, completely splitting the plane tends to be not recommended.
At the risk of giving advice above my level of comprehension, I'm going to say that I think either balanced output or output xform are going be mandatory. Otherwise you have either circulating ground currents or the giant loop you describe. I think unless your interconnects are short, very low resistance, and very low inductance, the quality might not be what you are aiming for.
Also, two other notes. I think series resistors on the signal lines are a great idea: they only slow the edge a little bit but provide some nice impedance to circulating currents. And, I would consider paying a lot of attention to the decoupling of all the ICs. When your "unimportant" 7400 IC switches garbage into the supply lines it is going to get into your "important" digital ICs, etc.
Guido Tent
dear Tiroth
Thank you for your mail, your remarks are correct, however, If you take a peek at the rest of the site
you will not that:
- we use a 4 layer board with all signal lines inbetween 2 ground layers (the 4th layer is used for "LF" lines like power and status signals)
- The ground planes are NOT interrupted at all
- We extensively decouple ALL IC's with a capacitor and series inductor (like I reccomend in my article)
- The RF excitation of I/O (like analog output) is mainly caused by the voltage build-up across the board. By design we kept that low
Going balanced may be a sollution, but due to the parasitic behaviour (lack of CM reduction) it won't help above say 30 MHz.
best regards
Guido Tent
tiroth
Guido Tent,
Sorry for the confusion! My reply was to (just) Guido, not yourself. I've read your article in the past and gotten some inspiration from it. :)
My comment about going balanced was only to prevent ground currents. (no need to connect ground!) Dr. Johnson commented once on Sigcon that maintaining a single connection from AGND to DGND was key, else digital currents almost invariably contaminate the analog plane, regardless of other measures taken.
Tyler
guido
Sorry for the confusion, i'll call myself Guido B. from now on... ;-)
Tyler, thanks for the reaction. I need feedback, so im am trying to understand your comments:
"Digital lines should be everywhere above (below) a solid ground plane" - Ok, this is a problem for me with the
digital logic. I only have 2 layers and i cannot use via's. Which i could have a 4 layer board.. :->
I need the two layers on the logic side to get the stuff routed. Guess i need more integrated logic..
I was not using the groundplane as return (the GND tracks are separate from the GND plane in the digital part).
I can do a redesign of the digital part and use the top layer as ground and the other layers for the other tracks.
See if i manage.
"there are going to be large circulating ground currents because there is not a low-inductance return from AGND"
Sorry, i cannot follow this. Moat: my english dictionary says it is the water around a castle. :->
Could you explain a bit more ?
The tracks through the analogue groundplane are returning GND from the logic part towards the DGND pin
(first passing the decoupling caps of the DAC, the SMD stuff you see on the top side).
I could make this plane also just a solid one.
"completely splitting the plane tends to be not recommended" I thought to have the two GND planes only as shielding.
The tracks on the top side ARE the GND tracks between analogue and digital connecting the analogue and digital parts
as short as possible (groundwise).
The "giant loop" is indeed the concern i have. Now i have more :->
After the DACs i need to make the outputstage (I/V conversion). There i can connect GNDs together again.
Series resistors in the data and ws line, ok sounds good. 500 Ohms i thought is a good value (?)
But i don't want to slow the edge on the clockline to the DAC, so i guess not in there.
Decoupling, yes all the logic chips have a cap (next to the gnd pin, as described by Guido Tent).
The clock divider has an oscon and two smd caps (like thorsten's adagio). The divider 74AC161 IC i think
is one of the "important" ICs: it divides the clock before it goes to the DACs :-)
So what to do
- Solid plane above the digital logic, used as gnd there?
- Solid plane above the analogue part, used as gnd there (solves my loopproblem)?
- if both=yes, connect the gnd planes in the middle of the board with a track following the clockline track from
the digital part to the analogue part (on the opposite side of the board offcause)?
- make one huge groundplane on the top for all GND and connect all to it.
Thank you for you reactions, i need them!
Guido, wellicht neem ik contact op om weer zo'n klokkie te kopen (11.8MHz).
Greetings,
Guido B.
tiroth
Guido B, ^_^
The ground plane in a digital circuit reduces EMI, but not just by shielding. It creates a low-inductance ground path, so your ground returns don't have to act like antennae. Having individual ground traces in a digital circuit is close to worst-case: these traces will have high inductance and cause a great deal of ground bounce. (and EMI, etc)
Remember, high speed digital currents follow the path of least inductance. You can't control them so easily as low-speed analog currents. If you don't present a low-impedance ground, they will travel on your supply lines instead.
You can make your own vias with PCB pins or bits of wire. As for "moat", your english is indeed correct, although this is an unusual usage. See my link above. You won't need the "multiple moats" but a single one will suffice. Recommended reading is "High Speed Digital Design" by the same Dr. Johnson.
P.S. Jocko managed to convince me to stay away from AC logic. Unless you need fast logic, definitely stick with HC, after that consider F(AST). You are doubling the amount of care needed when you move to AC from HC.
Guido Tent
dear all,
Good discussion going on, happy to note you guys take this subject serious (manufacturers could take note of this)
Let me take this opportunity to elaborate a little on loops, EMI, and groundbounce. Most results I list are measured results, from the time that I worked at Philips Semiconductors.
Currents run in loops (think currents, voltages are just the result of these and impedances).
A loop as such radiates. The amount depends on the loop area, frequency and current amplitude.
Consider a round loop. Connect a 2 wires, with their nodes at 3 o'clock and 9. Once a current runs through the loop, a voltage appears in-between the wires (due to the loop impedance)
This voltages excites both wires: We now have a di-pole antenna which radiates. The voltage source can be present in your groundplane, as currents run through the plane.
Consider an average PCB, with wires attached (and refered to ground, at least for RF) at left and right side. in the middle is your RF/digital chip, generating currents through the plane: there you are !
So 2 mechanisms cause radiation:
- Loops
- Voltages exciting wires
It depends on the size of the PCB, but at an average 10 cm, the loops start dominating at 500 MHz: Below the attached wires dominate. Above holds for antenna measurements at 3 meters distance.
Now back to the PCB design. Following above, you want to
- reduce loop size
- reduce the voltage build up across the plane (also for signal integrity (read: jitter)
Loop size reduction is obvious, as long as you asure that the current IS ABLE to run in the smallest loop possible. Design the PCB accordingly and make sure you know where currents run.
Besides reducing loop size, reduce the current and the bandwidth to the minmum required!
Voltage buildup can be reduced by preventing currents to run through the plane. A simple example is to (physically) locate the decoupling cap as close as possible to the ground pin of your IC ground pin. As such, the smallest piece of ground plane is incorporated.
On the subject of splitting grounplanes: I see reccommendations on only connecting the planes underneath the A/D or D/A part of the circuit. This connection closes the loop of the internally generated currents that cross the A to D border.
This may be allowed, but only if you are very sure that no other currents need to cross that same border !
all the best
Guido Tent
kenev
Hi all,
I see that the discussion goes on. I was away on wekkend - couldn't follow discussion. Really deep and thorough analysis, especially from "expert" Guido Tent. Unfortunately, I' m not a digital wizard and cannot contribute to this.
My question arose from reading this thread in relation to the way I should design the ground plane on my TDA1541 DAC. This will be fed directly from the I2S output of my CD-PRO2 cdp. That means, no other chip on board except two TDA1541s. From what I have understood, I come to the following configuration:
-two ground planes, 1 analog, 1 digital
-AGND and DGND of dac chips connected both to analog ground plane
-on the digital ground plane will be connected all the digital power supply circuitry, i.e., TL431 shunt regulator circuitry and bypass caps
-analog and digital ground planes connected together at one point
Any comments are welcomed.
Evangelos
guido
Hi all,
Evangelos, i am still searching too. Have the same problem, only my source is not
directly I2S, i have some logic in between (split I2S and reclocking). But also
two TDA's connected to digital.
I made a new version of the boards, with a digital groundplane and two
planes surrounding the DAC's (with moats inbetween (?)).
These are connected together on the board, like the multipleadc document suggested.
I needed 6 wires on the digital secion to complete the routing off all tracks.
If you have a look at the pdf's you see three tracks going from digital to each
DAC crossing the borders of the gnd layer. These are the clock, ws and dataline.
I still have the analogue ground connected as a 'star' to the agnd pin. Separate tracks
for decouplingcaps, output, VCC connector and decoupling caps and track to DGND pin.
Bad idea ?? I am still facing the problem of the AGND from the output pins being connected
via the digital gnd section.. Maybe i should try to get one start gnd circuit on the
analogue side or use transformers on the output like some designs or even one agnd plane.
Suggestions please!
Greetings,
Guido B.
kenev
Guido B.,
As I explained, I'm not a digital wizard. I was only hoping to get an idea of correct pcb design. I have not yet completed the pcb design, so, as you can figure out, I have not tested the project to report about.
What I have in mind, is to solder everything that is connected to ground directly on the graound plane and not on the traces side of the board. In this way, I will not have ground currents running through the bottom of the board. So, no star wiring on the traces side.
What I have designed so far seems to be well accommodated: that is, everything is above AGND plane except the digital supply section, which lies on top of the DGND plane.
The two ground planes will be connected together at one point - don't ask me where should that be, I have no idea - any suggestions?
Anyway, my design seems to be simpler than yours, since I don't have all the digital stuff proceeding the dac chip.
Evangelos
Guido Tent
quote:
Originally posted by guido B
If you have a look at the pdf's you see three tracks going from digital to each DAC crossing the borders of the gnd layer. These are the clock, ws and dataline.
I still have the analogue ground connected as a 'star' to the agnd pin. Separate tracks for decouplingcaps, output, VCC connector and decoupling caps and track to DGND pin.
Bad idea ?? I am still facing the problem of the AGND from the output pins being connected via the digital gnd section.. Maybe i should try to get one start gnd circuit on the
Guido B. [/B]
Guido
It does not look that bad at all !. Realize that the DA chip has its' groun pins as reference. The "local star" you made is OK !
Wrt outputs: Take them rom the chip. The ground of the outputs should not be hindered by digital currents, i'e' make sure by design these currents do not run here, and you will be comfortable
Guido
Page generated in 0.13512706756592 seconds with 17 queries,
spending 0.01786613 doing MySQL queries and 0.11726093 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
