diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Active subwoofer crossover question? - Click HERE for Original Thread
goldyrathore
I am making a small vented subwoofer but have some questions before I start.
1> I believe I will have to have a high pass filter somewhere around Fb since the
cone gets unloaded below this frequency. What sort of filter should I use and
how do I arrive at the right frequency?
2> I will also need a variable low pass filter. What should be the slope of this filter and what kind should it be?
3> I also need a high slope filter fixed at 200Hz so thet the Sub stays quiet above this and
does not reveal its location. I have read that sonodyne sub uses this approach. As per review it sounds great.
What sort of filter should I use and what should be the slope?
Thanks in advance,
Goldy
roddyama
quote:
[QUOTE]Originally posted by goldyrathore
[B]1> I believe I will have to have a high pass filter somewhere around Fb since the
This is a typical sub-sonic filter. It is usually a steep (24db/oct) hi-pass filter with f3 between 15 to 20 Hz. This was very important back in the record warp days and before subs became a common part of the system. Today it is less important, but probably more good than bad.
I like a 3rd order (18db/oct) lo-pass slope. Your shoud be at least that, if not higher. Particularly if you plan to run the sub higher than 100Hz.
I have to read about this one. 2 lo-pass filters you say?
sreten
Thanks in advance,
Goldy
1) sub-sonic filters are only mandatory with an LP source, it
could be worth investigating 6th order vented alignments as
these effectively include a 12/db octave sub-sonic filter.
If you go 6th order, recommend making the Q adjustable.
2) really depends on your main speakers characteristics,
whether mains are high pass filtered or not, and the trade
off between transient response (low order filters) vs. low
overlap (high order filters).
3) Whether this is necessary depends on the choice made in 2.
A 12/dB octave 2nd order Butterworth should be fine if needed.
:) sreten.
Page generated in 0.026415109634399 seconds with 17 queries,
spending 0.00622916 doing MySQL queries and 0.02018595 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
