diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
PCB Artwork Transfer Paper - Click HERE for Original Thread
Dear Daniel
i feel very trouble to printed circuit boards,
or anyone can give other easy method to print?
did anyone use this PCB Artwork Transfer Paper?
http://www.jdr.com/interact/item.asp?itemno=TTS-10
is it workable?
timc
I have used similar transfer paper several times with great results. Its very easy, much easier that photo etching.
Just make sure you don't crease the paper. I also find that you have to really Iron it a lot to get a good transfer.
Tim.
Dear Daniel
thanks for reply, could you tell me which similar transfer paper you are using? thanks.
tvi
I have used a paper made from <a href="http://www.watershedmedia.org/paper/paper-PROFbag.html">BAGASSE</a>, after ironing on to the very clean Blank PCB, I'd soak it in water for a few hours and the paper would just disintergrate, gave very good results. Of course I was lucky to have samples of Bagasse paper to experiment with.
Another method I have heard of but not tried uses the backing sheet from laser printer labels, just remove the labels and print on the shinny surface, when cooled the Toner should stay on the PCB when you peel off the label backing.
James
merbert
Another one that I found on the web was Press-n-Peel
Merbert
seangoesbonk
I've tried a few of the different papers made specifically for pcb transfers. I also tested EPSON "Photo Quality Ink Jet Paper" (#S041062) with an old IBM laser printer. Almost all of the papers produced good results, with the epson being one of the best. My little brother's high school is now using the epson paper with a t-shirt thermal transfer press, and have reported really good results.
The iron-on method is probably the easiest method I've ever used. Anyone who wants to try this method should try the epson paper. (It's way cheaper than most papers) The detail I've gotten from the iron-on is at par with the photo-resist method.
If you have access to a laser printer I'd definately recommend trying this method...
p.s. I realize I've written "method" 5 times(6 now), but I'm an electronics guy, not an english major...
p.s.s. Me fail english? Unpossible!!!
NickC
For cheap alternative
xerox the pcb board into a transprancy paper used for over-head project.
Then iron on the artwork on to the copper board.
Cheap and good but needs patience
Dear Daniel
i am using Epson inkjet printer, i will try the T-shirt transfer paper later, it seen to be a very easy method, thanks you for your precious comment!
Dear Daniel
i have seem the epson transfer paper, but i have some qeustion.
i found that the areas of colours and white are also coated on the T-shirt,
but for using in printed circuit, i hope that the areas of white are not coated, just the areas of colour are coated. then the etching solution will etch the areas of white only. it will maintain the copper in area of colour.
is it o.k.?
timc
Hi Daniel,
Sorry for the late reply, I have been on holidays, no computers allowed!
I use Press-n-Peel Transfer Film. It is quite expensive, but for me seems to be the most reliable and easy to use.
I have tried transparencies and normal paper, but found them inconsistent.
I have heard a lot about using the Label Backing, that and the Epsom paper I will try next.
Tim.
Dear Daniel
thanks, are you buy it on the internet?
is it reliable to buy Press-n-Peel in their site?
because i cannot find it in hong kong.
timc
I am able to bye it at local stores here in Australia (http://www.jaycar.com.au).
I have not tried ordering it over the internet (Press-n-peal site), but next time I need to buy some I might try it, the prices are a lot better than what I pay localy!
Tim.
swede
I have a pile of Press and Peel here, that a friend of mine bought over the net. I'm located in Sweden, so appearently international shipping works fine from Techniks Inc (see link above).
My only problem with PnP was that I was too moderate on the heat (I believe) so I had to touch my PCB up a bit with a permanent marker.
Though, much easier than UV transfer.
//magnus
timc
I find that I need the iron temprature quite high, higher than what the instructions imply and I iron continuously for a minute or so to get a good transfer (very minimal touchups required).
Tim.
kiwi_abroad
As the cheapest method possible, I have had great success with ironing on standard ordinary printer paper. The thing is you must compensate for the cheapness with a lot of care and effort. A few rules
1. Roughen the plain PCB with coarse steel wool to give the toner something to 'grab' to
2. Make sure the PCB is immaculetly clean and dry. I use detergent under hot water, followed by window cleaner to remove all traces of finger grease etc.
3. Use a LOT of pressure on the hottest iron you can get. Get the board very hot, then press down on the edge of the iron with as much force as you can muster. Cover the entire board.
4. The most important thing is to realise the paper does not release the toner. You must soak the board in water, and RUB the paper off with your fingers. If you do this, the tnor will not lift. NEVER lift or peel the paper off (If anybody follows this method, then at some point they will be tempted to try lifting, they will only try that once...). Keep the PCB wet.
5. When you think you've finished, leave the board to dry, any remaining paper fibres become visible, and you can continue.
I can get 15 mil traces using this method. Remember, it's cheap, but a lot of effort, and a small amount of trial and error, but quite repeatable.
macboy
DearDaniel, don't use t-shirt transfer paper. It will not work.
I think that you misread seangoesbonk's comment. He said that the students were using Epson "Photo Quality Ink Jet Paper" (#S041062) and an Epson t-shirt thermal transfer press (that's a special, big "iron" for quickly doing the transfers to t-shirts). He did not suggest using the t-shirt thermal transfer paper!
As another alternative, try laser-printing onto plain old transparencies. Make sure to use the kind that are laser printer friendly; others will just melt and ruin the printer. You can even photo-copy onto them, although all but the best and most well-maintained photocopiers will add some 'noise' to the artwork, which you may have to clean up manually later.
seangoesbonk
You are almost correct. I was using the Epson paper you described, (Epson "Photo Quality Ink Jet Paper" #S041062) but the thermal transfer press is not an Epson product.
The press is just a standard T-shirt press that is normally used either for fusing vinyl letters and numbers to the back of a sports jersey, or for transfering an iron-on image to fabric.
My high school had the luxury of such a thermal tranfer press, but I would imagine a standard household hand-held iron would work just fine. I would suggest placing something in between the iron and the photo paper to prevent the paper from burning onto the iron (otherwise your wife or mother will kill you!). The thermal transfer press had some sort of teflon sheet which would prevent the paper from burning. Another option would be to buy a cheap, used iron at a thrift store or garage sale.
sss
can this method work with ink jet printers ?
i know that t shirt transfer paper is working with regular printers ....
seangoesbonk
quote:
Originally posted by sss
can this method work with ink jet printers?
I haven't actually tried it, but as far as I know, ink-jet printers probably won't work.
I don't have a laser printer at home, so I usually export the PCB layout to a universal image file (such as *.jpg or *.pdf) and print it a friend's house. You could also get it printed at work/school or a print house (I don't think Israel has a Kinko's).
jason101
Hi friends, i am looking for a good color printer. I need to find a good B&W laser printer to print my response cards for my wedding invites. The paper is metallic cardstock. I need to find a good laser printer. Any suggestions? Are there printers that work with specialty paper or cardstock? What is a good laser printer for printing on metallic cardstock? Thank you so much in advance.
jaycee
I use Kodak "Ultima" printer paper, which is based on real gloss photographic paper. I only ever have a problem on large areas eg ground planes, and thats probably simply that the iron i use doesnt get hot enough (it was a crap one bought from a car boot sale!)
I'm using a Brother HL-1040 laser printer to do it. I started off after reading Tom Gootee's article on it :) The thing is, the Ultima paper works so well, that you dont need to soak it - instead you pull it off fairly carefully and the toner stays put.
MJL21193
Staples basic photo paper as recommended by Tom. Cheap - $30.00 for 100 sheets.
Printer is an HP 3050 laserjet.
I tried better photo paper like jaycee, and it came off much cleaner but I had to us a sheet of plain paper between it and the iron as it would stick to the back. Also took a lot more pressure because the paper is so thick.
I tried glossy magazine paper and this works but not good for fine detail. Also hard to see your print.
jaycee
Yep, I also have to use a sheet of paper so the iron doesnt stick, and the paper isnt too cheap (still cheaper than press-n-peel! though!). It works well though so i'm reluctant to change.
I couldn't find the Staples paper here in the UK - they're not quite as big a company here.
I have debated getting some kind of cheap health grill affair and modifying it so that it has 2 flat hot plates, and will clamp the board in the middle - sort of like a laminator on steroids!
Steerpike
Press-n-Peel is my favourite - it works very well, but is SO expensive here.
I get good results with magazine covers - the very shiney / glossy covers (e.g., the Oprah magazine - 'borrow' it from your wife!, or the catalogues from tour companies), but large copper fill areas don't fill well; it's great for thin tracks, less than 20mil.
But large areas are easy to touch up anyway.
I soak it in sodium hydroxide solution to get the paper off before etching in ferric chloride.
You should switch the printer's seting to things like 'economy mode = off' and 'print density = max'.
AndrewT
quote:
http://www.multimap.com/clients/bro...ich&scale=50000
jaycee
quote:
I live near Norwich City centre, so that is miles away :)
I did get my first pack of Kodak Ultima paper cheap because the idiots in Partners Stationers mis-labelled it though :)
Page generated in 0.067090034484863 seconds with 17 queries,
spending 0.00720692 doing MySQL queries and 0.05988312 doing PHP things.
Copyright ©1999-2009 diyAudio.com
