| adrianvanourti |
I have seen 2 MH bulbs.
- A big one with a screw socket
- A bulb with connectors on both sides
Whats the difference between these 2?
Bulb 1:
Bulb 2:
| 18wheeler |
| size of the light emitter. |
| uvodee |
really MH
looks like a flood lamp type.......
dat lijkt me geen MH te zijn, misschien heb ik het verkeerd maar dat plat type is meer een flood lamp en dat geeft een vlakke uitstraling
J-P
humm van Antwerpen? heb jaren in de Gr. Hondstraat gewoont, nu in Federal Way, WA USA |
| ace3000_1 |
Guys look at the top one, it looks hps to me even hpm, the second is definatley mh.
Trev |
| 18wheeler |
| have seen some ceramic MH bulbs like the first one. forgot which company produce it. |
| ace3000_1 |
| quote: | | have seen some ceramic MH bulbs like the first one. forgot which company produce it. |
Yeah that was my second thought, no good for projection though as that bulbs arc is miles too long, the cdm-t is also ceramic, ofcourse abit diff to the above design but id like to know the temp that the ceramic gets too lol i guess u could say white hot.
Trev |
| Figero |
Hey, this is my first post... wooooo!!!
Anyway, the first (screw) light is -NOT- MH, it is HPS (High Pressure Sodium). It will be far far too yellow for using in an OHP. |
| adrianvanourti |
Yes, now I see, the first one isn't a MH bulb.
This is a MH bulb :D (E40)
| MearCat |
| Is there any advantage is there having a double ended bulb over a screw in type (when both bulbs are MH)? |
| Figero |
| As far as I am awear it just means you need a different fitting for each. I think the purpose of have two types is for different situations - the double ended ones can be used in compact situations where there may be alot of vibrations whereas the screw fitting ones are (I think) cheaper to manufacture and have a more generic fitting. |
