diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
DMM, what accuracy should i be looking for - Click HERE for Original Thread
waben
Just about to buy a new DMM to replace my rather crappy current one.
But what kind of accuracy should i be looking for in a DMM?
I grasp the 'as great an accuracy as you can afford' concept...but that would mean buying something seriously expensive and most likely comlete overkill.
So what would do fine for amp building?
WB
Sch3mat1c
The most precise component you have in circuit might be 1 or 5% (being the resistors), and I imagine most DMMs are at least that precise, so don't worry about it. It is a poorly designed circuit to need even that much precision anyway!
Tim
annex666
quote:
Tim
I disagree with the previous post - the accuracy of the meter you buy should depend wholy on your intended purpose. The tolerance rating of a resistor only tells how far it will deviate from it's rating and not dictate how accurately you want to measure the voltage across or current passing through it.
You should ask yourself the question, "what is the allowable tolerance of any readings I will make?" - if you are working in a medical or military field then a DMM may have to be incredibly accurate (and high tolerance) for it's intended purpose, if you are only making simple circuit measurements on audio equipment then obviously lower accuracy and lower tolerances are acceptable.
peranders
0.5 - 0.2% is OK for hobby.
SY
You have to consider what you're using it for. Also, it's important to distinguish between precision and accuracy. Normally, precision is more important.
Christer
Although a good precision, good accuray DMM might occsionally
be useful, you may find it better to buy two chepaer DMMs instead,
since that allows you to keep track of two parameters simultaneously.
Magura
Just make sure its able to measure true RMS, it comes in handy when working on power supplies.
Magura:)
Christer
quote:
Magura:)
That's overrated I think, at least if you have a scope. Without
a scope, perhaps, but if you cannot see the waveform anyway...
annex666
I agree - often true RMS can be calculated with the appropriate correction factor.
Magura
quote:
True, but RMS measuring ability dosnt have to make the DMM more expensive, its just nice to have, hence the advice.
Magura:)
jackinnj
Magura:)
True RMS isn't always "true" --
a great DMM, if you care to work EBAY is the Hewlett Packard HP3403C -- this is perhaps the most acurate A.C. reading meter and can perform a variety of functions -- and they usually go for less than $50. Of course, this is a bench-type meter, not a hand-held, but a terrific bargain if you are have to measure a.c. or noise. Sorry, no resistance or current measurements, just volts!
the HP3478 is also an excellent true RMS reading meter, but these are more expensive, around $100 to $250. It's almost a lab-grade meter.
mbroker
The Fluke 187 is True RMS + DC and has a bandwidth to about 100kHz. But the price runs about US$350 new, which has kept me from buying it since my previous True RMS meter ($100 RS model from 1997) started to flake out more than a year ago....
I'm told that less expensive functional equivalents to the Fluke 187 exist, but I don't know of any off the top of my head.
jackinnj
for some reason there are a lot of HP 3456A meters for sale -- less than $100 -- this is a lab grade meter, 4 wire ohms etc -- it takes up a lot of space, but is an excellent high quality device:
here's a nice HP 34703A with a "buy it now" price of $35 -- and it's checked out:
peranders
quote:
Anything , I would say. Just state your budget and we can recommend it or not.
Write down all you wanted features first. It can help.
I have Fluke 77 a really good instrument which draws very little battery. Battery change once a year. I have also APPA305 a really good instrument and accurate (according to my calibration service) but it sucks 10 times the current of the Fluke! APPA is also rather slow when it comes to switching ranges, rather irritating. Fluke a :up: in that department. APPA has also no memory, irritating! Lot's of pros and cons.
leadbelly
To save a few bucks if you are indeed after a simple hobby-oriented meter, you can try what I did, which was buy a cheapo out of the back of an electronics magazine. I don't know who made it; it's a commodity 3-1/2 digit carrying the badge of the mail-order store, but it has taken more than its fair share of abuse and still works perfectly.
Page generated in 0.039958000183105 seconds with 17 queries,
spending 0.00900912 doing MySQL queries and 0.03094888 doing PHP things.
Please support our sponsor.
