diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
MAGNETIC PAINT & fm signsls - Click HERE for Original Thread
mltaunt
I am thinking of using this product
http://www.magnamagic.com/faq.asp
on the wall in my daughters bedroom. The It is described as iron particles in suspension. Will it block fm reception?
sek
Are You planning to put her under censorship? :smash:
mltaunt
Maybe, hadn't thought of that. I'm just worried about causing problems with FM reception on her boom box. It just occured to me that cordless phones might be a problem. This stuff sounds like the paint they use on the stealth bomber.
kelticwizard
I imagine a thin wire run from the antenna of the cordless phone base to the outside of the room would solve the cordless phone problem, if one exists. Same thing for boombox. Cell phones used in the room might be different.
I would call them and ask them, and ask for the name of the person giving the advice in case they say yes and it turns out that it does block them.
Now you have me wondering about using the stuff to paint a Mylar membrane to be put between two iron plates full of holes in order to make a magnetic version of an electrostatic speaker. :idea:
Da5id4Vz
Wow I thought this was going to be about something else all together....
Sorry to be off topic, but am I the only one who thought this was going to be about editing quad video tape?
Page generated in 0.037000894546509 seconds with 17 queries,
spending 0.02258706 doing MySQL queries and 0.01441383 doing PHP things.
Copyright ©1999-2009 diyAudio.com
