diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Magnetic parts sound worse because of... - Click HERE for Original Thread
Bernhard
... 1. The iron contained in these parts got histeresis when being magnetized by the current flowing :confused:
... 2. The "core" is physically too small and goes into saturation :scratch:
This is just my idea for an explanation, maybe we have some experts in magnetism here, who can help :cannotbe: by telling us how far for example the end cups (?) of resistors will be magnetized by the current.
Or if a wire contains iron, like the military coax RGxxx...
We all know that if the core of an output transformer of a tube amp is too small there are distortions from saturation.
Also cheap alloys may have magnetic histeresis.
Bernhard
SY
...the lack of any controlled listening tests to demonstrate this. Note that these parts work just fine in VHF circuits.
Before inventing explanations for a phenomenon, the rational experimenter will first determine if the phenomenon exists.
Oh, yes, and make sure that all your tools are demagnetized. Many of my screwdrivers and wire cutters carry quite a bit of magnetism. It's handy for positioning/removing parts and hardware, but what sort of sonic pollution might it be causing to the gear I build with it?
Bernhard
Bringing a magnetic resistor near to the coil of my 27 MHz plasma flame causes it to go off.
If it is found that hysteresis or saturation cause errors = distortion, no golden ears will be needed anymore for proof.
mrfeedback
As part of complete and permanent repairs to amplifiers, I often blanket resolder and then clean the amplifier and power supply stages.
On first power up I run the amplifer and allow it to idle for 1 to 2 hours whilst I adjust and allow bias currents to stabilise.
When this is complete, I then apply low level audio for a period, and recheck/adjust bias currents.
During this time, amplifiers subjected to this QA repair method can sound subtly gritty, notchy, strangely distorted and sort of 'wrong'.
Running up to clipping for the first time causes the amp to abruptly change in an instant, sounding 'easier' and more correct, and this new sonic character remains at lower levels and after power down and re-power cycles.
Before running to clip for the first time, briefly running at medium level and back down to original low level reveals subtle changes but not as profound as those after the first clipping event.
I have wondered if the heat of resoldering reduces residual magnetism in component leads, and large amplitude current pulses in the circuit cause a biased remagnetisation of component leads etc.
I have not bothered to find out if soldering provides sufficient temperature to cause minor demagnetisation in typical lead wire materials - feel free to correct me on this.
Eric.
Magura
quote:
Originally posted by Bernhard
27 MHz .
Im happy to inform you all that 27MHz is not an issue in audio equipment, even 100KHZ is out of range as far as im concerned. So all of your magnetic parts are fine........pheeew, that was nice to know :)
You will find magnetic PTFE caps in RF circuits...doing just fine btw.
Magura:)
Magura
quote:
Eric.
Off the top of my head, you dont need to get much on the other side of 100C to influence magnetism.
Magura :)
Bernhard
Magura:)
You will even find the most ugly ceramic caps in RF circuits.
In RF nobody cares about waveforms, except when the distortion causes undesired higher order power output...
Ever opened a TEK scope ?
You will NOT find a single magnetic resistor in it.
mrfeedback
Magura :)
Thanks.
If this is the case then this may be an explanation for the sonic changes.
Eric.
Bernhard
I do a search on google and what I found so far is that
if there is a current there is a magnetic field, and if there is iron, it has to be magnetized, and this means work has to be done, and this means loss.
The work to magnetize the material is not linear, specially arouns zero >> histeresis, so the loss is not linear >> distortion.
andy_c
Not true. In Doppler radar receivers for example, the level of third-order intermods determines how far below clutter that a target can be resolved. Most RF amplifiers have an OIP3 specification, because it's important in many applications.
SY
Magura:)
Well, that and the fact that Bernhard's experiment was not testing the phenomenon that he's concerned about here.
I'll bet the electronics that generated the 27 MHz plasma flame has components with magnetic materials in them. So does a CB radio.
dhaen
The thread started with an unproven assumption. Developments based on that cannot be sound.
Waveform is rather important in RF. Simply consider the 5th harmonic of an FM radio station operating around 100MHz, and it's effect on UHF TV.
Steve Eddy
It depends on the Curie temperature of the material. The Curie temperature for iron is over 700C.
se
sam9
"You will even find the most ugly ceramic caps in RF circuits."
Don't know much about RF, but have seen a comparisson of cap properties on a website, AVX I think, which indicates that ceramic caps have a higher bandwidth than others. This suggests that the word "even", above, is moot. I sounds like cermic would be a neccessity.
Steve Eddy
Sure. But how significant it is depends on the material as well as the magnitude and frequency of the magnetic field.
The magnetic domains that grow in response to the magnetic field and are responsible for the residual magnetization can only respond so fast. As frequency increases, they become less and less responsive which means less and less distortion.
Here's a THD versus frequency graph for a Jensen JT-11P-1 input transformer which illustrates this rather well:
se
Magura
quote:
se
As i remember it, the curie temperature is falling with the increasing percentage of copper in the alloy. Am i right on this one?
I know for a fact that some steel alloys (like impax from uddeholm) looses its magnetism to a great extend around 300C
Magura:)
Steve Eddy
Couldn't tell you for sure.
I'll take your word for it. :)
I was just pointing out that 100C wouldn't always be a safe assumption.
I think the basic idea though is irrelevant. Even if you wholly demagnetize say the steel end caps of a resistor using thermal energy or a demagnetizer, it's going to go right back to behaving the way it did the moment you apply a signal to it.
There seems to be this notion that this stuff somehow gets magnetized with a certain polarity. But the residual magnetization (remnance) changes polarity with the signal and the polarity it ends up with will depend on the polarity of the signal when it stopped.
But of course as soon as you turn the signal on again, the polarity of the residual magnetization changes again.
se
Magura
I fully agree steve. I joined this thread cause i think its sad to see so big amounts of money/- time wasted on something that is very questionable.
Its like with the isolation and the internal wireing....all theese 3 factors( i believe in only one of them(the one thats proven, but proven minimal influence)guess wich) are not even going to give you something you could call a percentage of improvement. Opposed to looking at the active devices. Even some of the passives(like caps and resistors) have some audiable effect for an amp.
If only people read some of the articles posted on passdiy.com
......it would be a little easier.
As posted earlier, magnetic components are used in RF circuits at many times the frequencies we see in an amp, now what makes people believe they wouldnt have solved the problem (or at least adressed it) if it was for real? After all, the RF guys have a somewhat bigger budget than the audio guys.
Magura :)
Bernhard
So why do all the good measuring instruments have non magnetic resistors inside ?
Siemens, Tek, R&S...
Mostly the ones without end caps like carbon composite.
Steve Eddy
I don't know that they do use non-magnetic resistors inside.
Though if they do, I have to wonder why good measuring equipment would use carbon comps which are very noisy, have large tolerances and drift significantly compared to film resistors.
se
mrfeedback
"There seems to be this notion that this stuff somehow gets magnetized with a certain polarity. But the residual magnetization (remnance) changes polarity with the signal and the polarity it ends up with will depend on the polarity of the signal when it stopped.
But of course as soon as you turn the signal on again, the polarity of the residual magnetization changes again."
Yes, this is correct for AC parts of a circuit.
For the parts of circuits that carry varying DC current, the magnetising current varies but does not reverse polarity.
IOW, for each half cycle a particular stage current varies from a minimum to a maximum and back again to the minimum.
All semiconductor (amplifier circuits etc.....) circuit stages are current direction concious in this manner.
"The magnetic domains that grow in response to the magnetic field and are responsible for the residual magnetization can only respond so fast. As frequency increases, they become less and less responsive which means less and less distortion."
So IOW there are delay/distortion characteristics on increasing going current changes and decreasing going current changes, and they will be different according to direction of change.
Audio signals are AC with zero DC offset which means the same area under the positive and negative curves BUT audio exhibits different slew rates and different peak amplitudes wrt signal half cycle polarity.
This adds up to a magnetic zero point different to the signal zero point, and may constitute a hysterisis point.
Eric.
Page generated in 0.072226047515869 seconds with 17 queries,
spending 0.01536369 doing MySQL queries and 0.05686235 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
