diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Where to get PCBs done in UK? - Click HERE for Original Thread
Frisbee78
Hi all!
I am looking for a place to get a PCB done but I don't know where to go.
My board is 5" x 5" simple face and doesn't need to be drilled.
It should also be either "tinned" (not sure of the english term for when you have the tracks covered with a layer of tin) or even better, have a solder mask.
I am looking for a figure in the odd of £7.50 with the cost of the board included.
Can you help?
daatkins
Very low volume PCB manufacturing in the UK is going to be expensive. Your target price of £7.50 is only going to happen if you order a large quantity of boards.
PCB-Pool (based in Ireland) offers very good rates and has a cost calculator on their website:
http://www.pcb-pool.com/uk_index.htm
Here's a typical price from them:
Single sided prototype board 125mm x 125mm: 38 EUR
Soldermask: 17.00 EUR
Silkscreen: 17.00 EUR
Overdelivery: 19.03 EUR (additional boards)
Test: 18.75 EUR
You can halve those prices by using Olimex in Bulgaria:
http://www.olimex.com/index.html
If your design is relativly simple then I suggest you look at makng it yourself. There's plenty of info to be found on this site if you use the search.
Nice one,
David.
Frisbee78
Thanks you David for this useful information.
Yes, it is a simple design but I cannot afford to invest into PCB hardware as I study at 1000 miles away from home (France) and I will have to bring back all my possessions back there eventually so I need to limit those to the max. Also, I can't really picture myself making PCBs in a 12x12 bedroom. Soldering is bad enough... ;)
As I said above, it is a simple design and I am not willing to pay 40€ (best quote from pcb-pool without shipping), where I can get the job done in France for about 10€ (tinned as well). :rolleyes:
I'll keep looking for something nearer, but if not...
Kram
Hello
You could try this place
http://www.rak.co.uk
Whilst I was on work experience last year my colleagues always used RAK to make up small quantites of PCBs for prototyping purposes. I always thought they were good quality and reasonably cheap. Though I never used them myself because I havent needed to, yet.
Hope that link helps
Mark. :)
Frisbee78
Thanks for your input Mark :)
I will check it out when I get a minute :)
mst
You might also try:Imprelec (01100 Oyonnax,France;tel:33-474730366/fax 33474730085)Then make single boards not too expensive,good quality but min order 20 euro,if I remember correct
Page generated in 0.032674074172974 seconds with 17 queries,
spending 0.01588917 doing MySQL queries and 0.01678491 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
