diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
fixed reg lm7915 - Click HERE for Original Thread
pete.a
im having prob's with a diy power supply. Its a split rail 15 0 15 well it should be. Input to the 7915 is 30v output is 21.7 v:confused:
Iv'e even used the suggested circuit as per nat sems web site, as the regs are a few inches away from the filter caps.
dhaen
Make sure:
It's a 79
That the pins are correct (different from 78!)
It's got a ground
There's a small cap across the oputput
It's got a load (unusual, but known with some regs)
And it'll work ;)
Centauri
quote:
Originally posted by dhaen
Make sure:
Yes, centre pin is output on these, not ground.
Cheers
JOE DIRT®
if the connections are good then check input on the neg. reg.....could be a bad cap or the reg is kiboshed....also try preloading the reg. with a 5k resistor for testing....it will also drain the cap between testing
DIRT®
pete.a
Hi guy's
Iv'e tried the ideas mentioned and it still ain't working.
Could it be due to the main filter caps being 10'000uf @40v?
The say upper limit for the reg is 35v
pete.a
Now explain this ?
the pos reg works fine 14.89v, changed the neg reg twice and still the same happens..21.7v:confused:
Im now thinking that it could be the transformer/rectifier, as ive got a dual secondary and iv'e tied two legs to ground.
Just so you know im a qualified electrician, so you can leave out the basic's if you get my drift.
What i may do but three week old Harry is taking our my sunday,
is to use two rectifer's instead of one.
Jax
The 40V rating of the capacitor has nothing with this to do but I'm not explaining why since you told us to leave out the basics. :clown:
If you are using the TO220 version of the regulators, make sure the 7915 mounting tab is not grounded, it's connected to the output (middle pin).
Other things to try, connect small 1 to 10 uF capacitors as close as possible to the input and output of the 7915. Negative regulators are more prone to oscillate.
ErikdeBest
I attached a picture that shows the middlepin as being the input. Pin 1 is ground and pin 3 is output.
Jax
Ops!
My memory isn't what it used to be, middle pin is od course the input. Sorry for the confusion :ashamed:
pete.a
Thanks for the images, iv'e got them written down in one of my books anyway.
Just split the tx secondaries and used two rectifers, one pos and one neg. Now getting 40v per rail under no load condition , bear in mind that its an 18v tx and one would expect around 22v before the rectifiers (output *1.414) if my memory is correct ?
And around what after the rectifiers ? 40v seems abit to high !!
dhaen
I've just tried 2 ST L7915CV.
With an input of only 28 volts and no load, they output 19.6v.
With a few mA loading, they drop down to the specified voltage.
I've only noticed this with the negative regulators.
peranders
Does the datesheet say anything about this or is it dependent of brand? Can't find anything in the National datasheet.
dhaen
According to the ST datasheet:
ST L7915CV
It seems that load regulation is only specified down to 5mA.
Christer
ST L7915CV
It is the same in the National datasheets, so it could be the catch.
Although not the same circuit, I also checked LM337. It also has
a similar catch and in addition specifies a minimum load current
to maintain regulation, in this case you may have to draw as much
as 10mA minimum.
Generally, I think it is wise to always have some load on a regulator
unless one is absolutely certain it is not required.
pete.a
Hi guy's
Im not sure what current this phono stage requires, i know it wont be to much , this is what this reg board if for. So should i use a loading resistor on the output of the reg? (tried a 1k5 @ 2w)But this made no difference.
Im being a cheapskate here by the way, as this kit come's with a power supply and i thought it would be easier and cheaper to build my own. The only difference between mine and there's is a pcb! and there's has three lots of reg's on each rail for different applications, and all being 15v regs ???
JonPike
Well, your 1k5 (100K ohms, right?) resistor is only drawing 150 microamps at 15V.. so that isn't quite up to the 5-10mA the regulator needs to regulate.
Try a 3000 to 1500 ohm resistor for that current range.. Assuming you didn't get caught out by the different pinout of the neg regulator, and it's smoked, then you should be working..
On the really high rectified voltage, it's typical for transformer AC voltage to be quoted at a certain load.. transformers tend not to regulate very well (depends, and smaller are worse) so you might be starting rather high, the rectifier will give you the peak if has next to no load.. so you can be pretty high from expected.
Check your wiring with the transformer though.. You don't want any higher input voltage than you need, for a couple of reasons: You dont want to exceed the max rating, as you've already picked up on, and you will have to burn more power in the regulator while dropping the higher voltage. Remember, every volt you drop equals the current times that voltage of heat in the regulator!
So, if you're actually dropping 40V to 15V, and your amp or whatever takes 100mA, that's 25 volts drop times .1A = 2.5 watts, and you're going to have a really hot regulator! As opposed to say, 18v, and you only have .3W to dissapate, maybe you dont even need a heat sink..
I'd try to arrange the transformer/rectifier setup to give me as close to (but remember the min dropout voltage, you need a volt or two headroom) my regulated voltage as I can. Using a resistor that simulates the total load of the final circuit so I'd know what the "real" voltages will be under load.
Let us know how it turns out!
Jon
pete.a
Thanks for your reply Jon.
I will try that method at the weekend , don't get enough time in the week, as our new born take's up most of my evening !!!
I used a 1500ohm to load the reg, but iv'e got some more so i will series a few. Put the caps be in the circuit and found that i was picking up the ripple voltage...duurrr silly me !!! Back to 30v now:)
So i'll let you anyway....i wished id spent more time looking and listening to the teachers at school, than the windows ????
JonPike
OK, sorry for missing the nomenclature there, thought it meant 1.5 x 10E5..
If you gave it 10ma load and it didn't start regulating, something's wrong and more probably won't change things. Regulator might be bad..
How are you wiring the transformer, diodes and ground again? Just re-read the part about only one diode (total?? each side?) and am wondering.
pete.a
Hi Jon,
I found the fault.
Hallelujah.
After all that ****ing in the wind, it was a dry joint on the ground of the test point...duurr Now got 14.88v with a 1500ohm load.
Thanks to everyone for the help on this, its made my day and now im off to bed.
Does anyone out there have two 470uf @25v caps that they could possibly give to me?. They must be less than 10mm in dia, tried maplin but to no avail. Rs only sell them in 5s and Farnell won't do orders less than £10.
Thanks Guys.
Pete.
JonPike
Congrats!
Yep, the ol' Sherlock Holmes thing.. "If you have eliminated all the other possibilites... "
Many times I've gotten to a head-scratching point, walk away for a time.. to come back and not even BELIEVE the very obvious thing I wasn't seeing for so long.
I've learned it's important to not stare too long at a problem, and be able to "adjust my eyes" or "change my perception" by leaving it for a while, then coming back.
Probably want to leave it in there, or one on both regulators, unless heating is a problem. Curious what your unregulated voltage ended up to be, with the load and proper ground...
pete.a
Hi Jon,
The voltage was 18.89v no load..sorry forgot to mention that in my moment of TRIUMPH.
Thanks Jon.
JonPike
Cool.. 4 volts drop.. not too bad, beats 25!! Don't forget to heat sink them (and remember that the neg reg will have voltage on the heatsink!) if they're too hot..
General test, if you can't keep your finger on it for more than 5-6 seconds or so, with their full operating load, it's probably above 50C and you want to cool it.
Page generated in 0.049617052078247 seconds with 17 queries,
spending 0.00684118 doing MySQL queries and 0.04277587 doing PHP things.
Copyright ©1999-2009 diyAudio.com
