diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
swapping 2955/3055's for new on semi mjl4281A/mjl4202A ? - Click HERE for Original Thread
Tensop
Hi guys, im in the middle of building an sc480 silicon chip amp, and was wondering if theres are directly replacable?
Thanks ;)
Tensop
azira
Just passing through the 'duh' test but uh... My 3055's are TO-220 and the 4281's are much bigger (TO-264)...
sam9
Might be do-able. The packages are differennt but the pin spacing and pin-outs are the same or nearly so. Note, for example that the ESP P3A pcb can take either. The question of physical space remains. If all else fails a bit of air wiring might make is work.
I have no opinion whether you will actually hear a difference as other factors are involved as well.
richie00boy
There's a few variations of 3055s and 2955s. TIP3055 are in large package so MJ4281 will drop straight in. MJE3055 (or it may be MJL3055, I forget) are TO220 so it may be difficult.
Tensop
thanks for the tips guys. Physical spacing wont be a problem. i was just wondering if there was any electrical difference(for example the gain between the 2955 and its equivilent would be different). I'm planning to use other transistors as the power rating of these isnt as great as others that are easily availble :)
Tensop
Dilby©
Is there a conclusion to this idea? I'm considering doing the same thing with mine..
CBS240
Generally, variables like Hfe, Vce, Ic, SOA, speed, and thermal resistance to case may be a factor here. Just compare the datasheets.
AndrewT
which way are you swapping?
Are you planning to use the To220 3055s? instead of the To264 4302s?
Greg Erskine
Hi AndrewT,
The original SC480 kit has 2 versions, one uses 2 x TIP3055/2 x TIP2955 and the other 2 x 2N3055/2 x 2MJ2955 for output devices.
Dilby©
Looking at the schematic, I would "guess" substituting higher speed more linear output devices should be OK. I would suggest trying it for one channel and post the results. Its an EF output stage which I believe are less prone to oscillations.
regards
Page generated in 0.023478031158447 seconds with 16 queries,
spending 0.00674176 doing MySQL queries and 0.01673627 doing PHP things.
Copyright ©1999-2009 diyAudio.com
