diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Atomic bombs and decibels. - Click HERE for Original Thread
Circlotron
That dual paragon of both engineering achievement and human stupidity must hold some fascination for all those interested in sounds / loud noises. First generation fission bombs reportedly had an equivalent explosive power of 4000-5000 tons of TNT. That's quite a bit of noise by anyone's standards. Enough to flatten a city. Now consider this - by the mid to late 1950's the then superpowers were testing fusion bombs in the 50,000,000 ton range. :smash: The point is, that is over 40dB louder than those earlier devices. :dead:
janneman
...but what is your REAL point?;)
Jan Didden
Fuling
I think what Circlotron really wants is to build a choke loaded H-bomb powered subwoofer.:D
setmenu
OK
Imagine how loud the sun would be if we could hear it:bigeyes:
hehe
Setmenu
wintermute
quote:
So are you saying we need to build a hydrogen bomb in order to make any significant difference to the loudness of our audio systems :devilr:
That's a significant cost for an extra 40db!!!!! ;)
Tony.
edit: probably a bit obtuse but were you reffering by any chance to the law of diminishing returns?
Keld
Hi
Max dB in air is something like 190. So if we want to go higher maybe scuba gear and a new bigger Bikini bomb .
Keld
sobazz
By the way - when does sound pressure become lethal? I know that danish scientist developing instruments for satelites test the outcome in a speciel chamber designed for extreme SPL. Being in there while testing is LETHAL.
phase_accurate
Could even be more in the nearfield - since the air pressure will temporarily be increased by some extent, allowing for much larger pressure variations. :devilr:
Charles
Christer
quote:
Originally posted by Keld
Hi
Keld
Not at all. At some level, perhaps 190dB, you will start to get a
quite heavy assymetric clipping, though.
tpenguin
Actually, the first bombs were in the 15-25 kiloton range, and while very destructive (and loud), still not nearly enough to destroy an entire large city. While the US did at one time have at least a few 120 megaton bombs in its arsenal, the Soviet Union were the only ones to ever actually detonate a bomb with a yield greater than 10 megatons, their so-called "monster bomb" at 60 megatons. That is certainly enough to flatten a large city and its suburbs.
roddyama
I would suspect that it would consist mostly of a single very high pressure wave (very assymetric) traveling outward in all directions
RHosch
I could tell you the free field pressure for a given yield at a given standoff distance, but... well, that's classified. ;)
moses
http://nuclearweaponarchive.org/hew...ests/100ton.jpg
Or you could just do that :)
That's 100 tons of Comp B - what they used to calibrate the test equipment.
On a side note - the worlds first nuclear explosion, Trinity, was something like 20kt. The highest yield weapon the US ever produced was the MK41 however it was a 3 stage bomb and was never actually tested in it's final configuration(which was suppost to yield some 25MT).
uvodee
and that is about 15 years afo, I read a paper on a sound bomb, if my memory still serves me, it had something to do with neutrons.
it purpose of this weapon was to kill all live but leave buildings and all it's pubilc utilities stand (no harm to water, gas etc.... )
it's explosion is actually a low, very low frequency that would be just loud enough to kill but not to destruct.
And as a added info, I am pretty sure that some country has this device.
Jean-Pierre
Eommmmmmmm
Sch3mat1c
Neutron bombs have to do with radiation (neutron flux) irradiating everything. Particularly gruesome injuries due to radiation burns, etc. :bigeyes:
TIm
uvodee
quote:
TIm
cause the real advantage? of it was that nothing got radiated, only killed by low, ultra low and loud frequencies........
of I could only remember the name of the darn thing...
J-P
jewilson
So what kind of woofers an power amps do you need to get to that level 190db. Maybe it should be horn loaded and we could use the power converter 50gigiwatts from Back to Future.
muskgrave
only 1.21 gigawatts was necessary to power the delorean..although it did require a nuclear reaction, thus the necessity of plutonium.
Dr. Brown (who's middle name was Lathrop, by the way), for some reason always pronounced it "jigawatts"...
a little off the subject..but of great importance to those who may have been misguided in the sacred history of Hill Valley :)
dlv
Circlotron
quote:
Originally posted by tpenguin
While the US did at one time have at least a few 120 megaton bombs in its arsenal *snip*
:bigeyes: What I think would be way cool (if you had a spare planet that didn't matter) would be to detonate one of those things several miles deep in the ocean. I imagine it would make an enormous ball of superheated steam pushing against the water at 3 or 4 tons per square inch at that depth. The steam ball would start to rise toward the surface but at it went it would cool down and condense, giving up it's heat to the cold ocean water. By the time it got to the top there might be nothing left except a rising thermal current of warm water. I wonder how far the shock wave would travel, seeing that the water is basically incompressible. If you were a safe distance away, what would a shock wave in the water feel like?
SY
Circlotron, here in the US, the practice of dropping a stick of dynamite in the pond to catch fish is effective but frowned upon!;)
Sch3mat1c
Yeah it'd probably work.. conventional explosives create steam, CO2 and nitrogen, among other things depending on what type it is. A nuke has nowhere near 1 ton of TNT, yet has a yield of many thousand times that, so the result may indeed leave little "burp".
Oh- not to forget that megaton nukes are fusion devices, so they'll be giving off a good bit of helium. Although I imagine again it'll be thousands of times less than conventional explosives.
The low frequency burst you speak of would travel around the world (of course). (Is our hypothetical world covered in water? ;) ) It's hard to say if, when the shockwave breaks the surface above the device, if it wouldn't throw much water up. Most depth charges seem to swell things a bit, and with a fraction of a gigaton....
The shockwave at any point would certainly be tall, whether or not it's travelling in deep water. Probably make a reasonable tsunami too. In fact I seem to remember something about nukes placed in the ocean threatening coastal cities. Wavelength would probably be like...miles... Certainly you'd feel it...don't know if there *is* a safe distance besides being in the middle of a continent! :D
Tim (just woke up so please rip this post up as you feel necessary :p )
wintermute
Have you had ASIO knocking on your door yet Circlotron ;)
Tony.
Chris8sirhC
speaking of deadly sound waves.....
Years ago while reading through the directory files of Borelands Turbo C++ (with new multicolored menus (12 colors....)) I came across this under the "sound" heading
"True story: 7 Hz is the resonance frequency of a chickens skull cavity. This was determined empirically in Australia, where a new factory generating 7 - Hz tones was located too close to a chicken ranch: When the factory started up, all the chickens died."
jewilson
Now if you could only get a Memorex tape of Ella Fitzgerald amplified to a 190dB, now that world shatter any world.
:bigeyes:
moses
uvodee, perhaps your thinking of a low-yield earth penatrating nuke, which in theory, if it worked correctly, would be pretty much radiation free other then at the site of detonation would be easily contained. Neutron bombs on the other hand are still dirty, still leave radiation to a point, and can do some really nasty thing to certain steels including radiating them for a period of time(ie, radiating a tanks armor making the tank itself lethal to it's crew).
angel
Just a few small points to add to this discussion.. =)
First off, the limit of 190dB in air is not, as I recall, the absolute limit. For one thing, a sound pressure level of 192dB is required to shatter steel, and I believe Cerwin-Vega did this at a demonstration once, by heaping a hundred or so of their largest speakers into a truck, and connecting them to a triphase outlet or somesuch. Also, you must consider that the pressure waves from the nuclear strikes in Hiroshima and Nagasaki propagated at something like 2km/sec, which far exceeds the usual ~330m/sec limit. The estimated sound pressure at ground zero was 210dB as I recall.
Second, someone wondered about the required sound pressure to kill a human.. The tympanic membrane will typically rupture between 2 and 5 psi. At 5 psi, the body will be accelerated with sufficient force to cause 50% mortality from head injuries if an obstruction is hit. I am not certain, but I seem to recall that the hollow viscera will rupture somewhere between 7 and 30 psi, which is serious, to say the least.:bigeyes:
I'm not sure what decibel levels this translates to..
I do seem to recall that shellshock can occur at some 140dB-150dB, which happened at a particular subwoofer demonstration, where one of the participants was rushed off to a hospital. One more reason why you should not operate a sixpack of Avantgarde basshorns at maximum output, or for that matter connect them to anything with a DC offset. :whazzat:
millwood
quote:
I thought that was exactly what they did with snake fish in the south a couple years ago.
another way is to use high voltage electric shocks.
as to sound bomb, there were talks of subsonic sound bombs: they cause some pretty serious damages to internal organs from subsonic sound waves (like 6 hz or so). not sure if there is actually a weapon out of that.
Chris8sirhC
I'm pretty sure those subsonic bombs operate on the same principle as the chicken deaths i mentioned above. Hit the resonance freq of a particular part of the body and..... Just curious, is that even possible, or is that story completely false?
RHosch
Standoff tests like that are very useful for approximating nuclear overpresure airblast effects, but the results of these conventional explosives tests are typically classified as well. ;)
millwood
quote:
sorry that I missed the chicken story. the last time I read about a subsonic bomb was in the 1980s. as I recall, there were some human / animal trials, and the 'weapon' itself is like a huge fan.
supposedly it wasn't terribly efficient, :).
Other than that, i haven't read a single thing about it so I suppose it could be a hoax of some sorts. But it does make logic sense.
Chris8sirhC
sounds like a job for the 'Myth Busters' on the Discovery channel. Only thing, if it turns out to be true.... it will be their final episode...
KBK
quote:
That is the sound of one fission farting.
Also, this subject has been covered at length at Keelynet. The chicken farm thing was due to a hydro plant (coal fired) opening at one end of a canyon-like area in France, and the chicken farm was at the other end. The loading at the farm which was up against the cliff... of course, brought the pressure levels up a bit.
The bladder of humans will malfunction in most people at about 14 hz. People will wet themselves. There are also other frquencies that pertain to the brain cavity, etc. None as fun or effective as the bladder one though...
SY
I always thought that would be a good name for a band.
Is this term known outside the US?
angel
What SPL is required at the mentioned 14Hz frequency to actually cause such a bladder malfunction, and is it temporary or permanent?
Given how 14Hz is in the region where it needs to get pretty loud in order to be audible (and then usually as pulses, or a sensation of increased 'tension' in the air- people who live near industrial plants will know what I'm talking about)... might make for some really funky practical jokes.. :bigeyes:
Page generated in 0.075299024581909 seconds with 17 queries,
spending 0.00643349 doing MySQL queries and 0.06886554 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
