diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
100K Noble logarithmic pot - Click HERE for Original Thread
2Bak
I'm building another GC using the below schematic.
I have a Noble 100K logarithmic pot, type 204.
I've seen that people recommend linear pots for GC's.
Can I compensate in some way using this logarithmic Noble? If possible, what should I do...?
By the way, why are logarithmic pots not recommended?
(Haven't soldered it in yet, so I haven't heard the amp in action with this Noble).
Thanks.
/Jan
2Bak
this one
Peter Daniel
I'm very curious why they are not recommended? I used exactly the same pot in the same circuit and it works fine.
Wht is not recommended, is the 100k value. I'd rather go for 50K, but if not available 100k will work too. Actually, I tried linear pot in this location, and I prefer the action of the logarythmic one.
2Bak
Thanks for your information, Peter. I didn't mean that Nobles were supposed to be not recommended.
However, in this schematic someone (?) recommends linear tapers: http://ampchipdiy.com/invertedLM3875_r2_1.gif
I will use this 100K Noble 'cause I have it already.
/Jan
Peter Daniel
Well, I tried both (linear and logarythmic) and logarythmic gives better control range. BTW, those Nobles are pretty good sounding pots.
Also, Noble 204 curve has pretty nice split and might work better than some other logarythmic pots (with 10/90 split)
2Bak
Yep, I've seen you mention this before...I tried an old Alps Black Beauty 100K first, but took it out 'cause channels were not in balance. Looking forward to trying this Noble.
GrahamnDodder
Peter-
I am building stepped attenuators for an LM3987 IGC feeding a pair of 90db speakers. But I only have 12 steps to my switches. Can you rec 12 resistor values for a most useful set of 12 steps?
Thanks,
GnD
Peter Daniel
There is a 12 step attenuator in this link http://www.geocities.com/rjm003.geo...dio/diy_gc.html
If I would be doing one for me, I would use 2db steps from full volume down (-22dB would be 11 pos and OFF would be the last one). I don't listen at rally low volumes so this would work well for me.
In here, there are some values listed as well: http://www.penguinlovers.net/audio/Attenuator.html
Another calculator here: http://homepages.tcp.co.uk/~nroberts/shunt.html
Page generated in 0.041929006576538 seconds with 17 queries,
spending 0.02188277 doing MySQL queries and 0.02004623 doing PHP things.
Copyright ©1999-2009 diyAudio.com
