diyAudio.com diyAudio Forums Archive > Top > Source > Digital
CS8414 v 8412 - Click HERE for Original Thread
fmak
Elliott (Counterpoint Service) suggests replacing DACs with CS8412 with 8414 for improved sound. Anyone tried this?
Josep
I replaced the CS8412 by the CS8414 in my Counterpoint DA-10 and the result are very impressive.
The problem is the different format (I use an Adapter SOIC to DIL) and this chip is difficult to find in Europe.
stewcle
I have some extra CS8414's if you are interested my cost was $14 plus whatever postage needed.
Email me at stewcle@yahoo.com
Elso Kwak
Hi Josep,
Very interesting! Did you use the "Wildmonkeysects" loopfilter on the CS8412? What are the differences in sound between the CS1812 & 8414? Could you elaborate on that?;)
Never thought the CS8414 was better on redbook CD's (44.1 kHz sampling frequency):)
Josep
Elso,
I dont know how loopfilter is implemented in my DA-10,
I only changed the receiver and the the result are more detail, better bass and sound more natural and musical.
Mike Elliot (Counterpoint) speak about this in www.altavistaaudio.com/DA-10.html
fmak
[QUOTE]Originally posted by Elso Kwak
Can you explain what the loop filter is? I shall try it.
Elso Kwak
Hi Josep ,
<B>T</B>hanks for the answer, I will give it try. Which DAC are you using with the CS8414?
Fmak you can find the loopfilter for the CS8414 here:
http://www.audioasylum.com/audio/tw...ages/44352.html
and the loop filter for the CS8412 here:
http://www.audioasylum.com/audio/tw...ages/30297.html
I am a bit puzzled by the advice of Mike Elliot as the loopfilter for the CS8414 is different from the loopfilter of the CS8412! After exchanging the IC the loop filter should be modified too!
Josep I envie you for being the owner of a DA-10. Very nice piece of equipment.:)
fmak
Different designers/manufacturers use different values, presumably optimised. Why call it loop filter?
Elso Kwak
Hi fmak,
It is a low pass filter for the PLL (Phase Locked Loop) of the CS8412 or 8414; hence the name loopfilter.
Elso Kwak
Hi Josep,
I just compared the CS8414 with the CS8412 in my NON-OS KWAK-DAC. (AD1865N-K).
I can <B>NOT</B> confirm your findings; on the contrary bass is slightly less with the CS8414. But the other attributes you described are very similar to the CS18412.:confused:
Page generated in 0.035566091537476 seconds with 17 queries,
spending 0.01572013 doing MySQL queries and 0.01984596 doing PHP things.
Copyright ©1999-2009 diyAudio.com
