diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Bridge/parallel calculations?? - Click HERE for Original Thread
JDeV
Can somebody please post formula for calculating the max. out power (at various supply voltage levels) of a bridge/parallel combination using LM4780 (for instance)? I plan to use this with either Dayton Titanic or Adire DPL 12 for active subwoofer - if there is enough power ;)
Thanx for any help.
Rob M
Take a look at the "design guides" here:
http://www.national.com/appinfo/audio/
JDeV
I looked at that earlier, they don't support the LM4780 and I am not sure what the combined (bridged/parallel) result must be.
In the BPA-200 application sheet , http://www.national.com/appinfo/aud...cation_Note.pdf , they also explain how to calulate the bridged Pmax, but not bridg/paral.
peranders
Check these especially the Excel file
http://www.national.com/an/AN/AN-1192.pdf
http://www.national.com/appinfo/aud...ign_Guide13.xls
http://www.national.com/appinfo/aud...esign_Guide.pdf
JDeV
quote:
Originally posted by peranders
Check these
AN-1192 and PAB-200 are basically the same document, 1st one is just a later version. The design guides is the same as what Rob M suggested.
peranders
I recommend that you take a look at the Excel calculations.
Page generated in 0.033021926879883 seconds with 17 queries,
spending 0.01584792 doing MySQL queries and 0.01717401 doing PHP things.
Copyright ©1999-2009 diyAudio.com
