diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
4570C and 5218A - Click HERE for Original Thread
Mr. Triatic
hi guys (and gals)!
i have scanned the net for information/specs. on these devices (opamps) ...but nothing, does anyone have any clue regarding the specs.?
those little fellows are encapsulated in 8 pin DIP package.
Are they dual opamps or just single ones?
any HELP would be appreciated
kind regards
/Ludvig.
Tube_Dude
Hi Ludvig!
They are dual op amp and bipolars...i never find nothing about them in the net.
They are very much used by the majors japonese manufacturers.(Pioneer , Onkyo,etc) in the phono input stage!
Is not much , but is all i know!! :)
Mr. Triatic
wonderful!
then i probably can replace them with a dual OPA2134...?!
the victim is a Denon DA-500 DAC, i ripped off the cover and spotted those opamps...
Cheers mate, thanks for the quick reply!
/Ludvig.
EIRA
Hi Ludwig... I planned to change these M5218 as well. Did you do it (back then in 2002)? and did it work out satisfactory?
Leolabs
If i was not wrong,datasheets of both are available at www.datasheetarchive.com.Personally for replacement of them,i will try any dual audio OP-AMP as long as pins compatibility is not an issue.:)
macboy
You'll have more luck searching for M5218 (with A, AF, or AFP suffixes) and NJM4570 or JRC4570.
EIRA
I found the datasheet here: http://www.datasheetarchive.com/sea...5218&sType=part
I changed the 5218 (slew rate 3 V/us) by and OPA2134 (slew rate 20 V/us) and put two larger capacitors in the power supply. A great improvement. more power in a shorte base, more open sound, more solid, softer mid. Absolute worthewile the 10 Euro's I paid for the 2134!
Page generated in 0.026701927185059 seconds with 17 queries,
spending 0.00796723 doing MySQL queries and 0.01873469 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
