diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Upfiring or Downfiring? - Click HERE for Original Thread
masterp2
In a sealed, .5 Qtc stereo sub design, does it make a difference?
The upfiring design would have a plate about 5" offset from the driver, which is 2 feet off the ground. Are there any sonic pro's/con's to this upfiring idea?
Michael
Dustin Haug
Can't say for sure if there's a sonic difference cause I've never heard an upfiring sub. But I'd go with downfiring since then you can actually set things on top of the sub. The woofer will be better protected also.
ThingyNess
It actually depends a lot on the driver. With some it can be beneficial to mount down/upfiring, and with others it can be highly detrimental, and others it will make little to no difference.
If you can let us know which driver you're using, we'll be able to help a little more.
Page generated in 0.015619039535522 seconds with 16 queries,
spending 0.00555229 doing MySQL queries and 0.01006675 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
