diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
About free sample at Onsemi - Click HERE for Original Thread
MaXiZ
Is there a way to order free sample at onsemi without have a credit card? Consider that i'm from italy! :)
Magura
What is it you need from ON semi??
Magura
MaXiZ
some power audio amplifier chips
Magura
Then go buy them....the samples program is not made to sponsor your private hobby projects that you dont feel like paying for!!!!
If you abuse the samples program like that, in a short while it will be shut down, and then we cant get the parts through the samples program that we cant get elsewhere......a very bad situation.
Magura
And btw, if you had searched (as you ticked off on the start a new thread page) , youd find another couple of threads with the same question and the same answer.
MAgura
MaXiZ
u're right but i still have the same problem if i would like to BUY them becouse i need a credit card. And i don't own one?? Some other way to have them anyway?
Magura
Find someone who does hold a creditcard....if youre under 18, youre gonna find it hard to get around without your parents helping you with purchasing.
Magura
Duo
Magura: Who is this "we"? Are you a hobbyist? or do you work for a business that needs these parts?
Magura
We was meant as in the hobby world....but I need the samples in both matters myself sometimes. In my case i use the program for getting the component prototypes.....those simply cant be bought.
Magura
sam9
I don't know about the specifics of this particular case, but the reason some have requested samples is that some parts are available only as samples or in very large quantities such as a commitment for 1000/month for 6 months!
While I have not obtained transistors as "samples", a year or so ago I was trying to replace a switch in an old piece of equipment. It was only obtainible in large quantities ditect from the factory. I called them to request the name of a distributor that might help. That's when I found out that was not a possability. I explained why I needed two switches and the marketing guy offered to send them to me as samples as there was no way the "system" could deal with an order of 2.
Magura
Thats pretty much what i meant....its a very nice last resort in such cases.
The problem is that obviously a lot of people have got the impression that the samples programs are made for them to build their hobby electronics for free, or even worse....to offer the aquired samples for sale on ebay or the like.
Cheers
Magura
uvodee
Washington state has 6 million habitants and there is not one place where you can buy a LM 3875 of the shelve .........
The only place you can get them is on line with Digi key, mouser etc.... or as samples .......
J-P.
Magura
quote:
J-P.
Its the same situation most places in the world. That dosnt give people the right to rip off the manufacturers!!
As you stated yourself....you can buy the chip. It should be common sense that it should be bought then.
Magura
uvodee
that I would try to get the chip as sample...
by the way, one can by the chip almost cheaper than free samples (for 2 pieces NS charges 8 dollars shipping andhandling. I can buy the chip from surplus (yes the Lm 3875T) from s surplus dealer for $4.50 and they ship much faster!!!!!!!!!!t
However.... you should realize that for these co's sending me 2, 3 or even 10 of these chips is a pure waste of time and probably run's the the $100 all together.......
1) order intake
2) order processing
3)invoicing
4) shipping
5) follow up
6)running the website and over head costs
for an order of $25... their cost is probably 4 times as much!
pretty much the same as you go to a grocery, the receipt costs run likeley in the $tens........
J-P
Magura
J-P
Dont get me wrong....this isnt aimed at you as a person, but at a load of people on this forum. This subject have been up a few times before. Hence the very square attitude.
I know perfectly well that its waste in any aspect to order anything as samples for all parts involved, if it isnt because you cant get the parts othervise. When i have ordered samples for buisness use its been a true pain, cause ist such a slow process in most cases. Not to mention companies that offers samples, but mess up somewhere on the way, so you end up with the wrong component or none at all......i have a few companies on the "black list" for such incidents.
All said, i usually choose ON for buisness use, since they offer the absolute best service on the market, and they are usually competitive in price matters.
Cheers
Magura
Bricolo
Since when does ON ask for a credit card to order samples?
Magura
If you dont have a company email....i guess :)
In an attempt of limiting the expense of private people using the program.
Cheers
Magura
Page generated in 0.038058042526245 seconds with 17 queries,
spending 0.00727487 doing MySQL queries and 0.03078318 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
