diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
VBIGC, running the buffer at +/- 50V - Click HERE for Original Thread
Shoog
Do I need to do any modifications to run the Valve Buffer at +/-50V rails, as I have a nice old EI transformer with heater coil output which I can use.
Also what is the feeling about running the heater power supply with just a CRC filter.
Shoog
planet10
I don't know if you need to tweak values, but it should work better with the extra V.
dave
Page generated in 0.01819109916687 seconds with 16 queries,
spending 0.00863838 doing MySQL queries and 0.00955272 doing PHP things.
Copyright ©1999-2009 diyAudio.com
