| Dxvideo |
-Should I use shielded cables for gainclones box inside signal connections?
-If I use normal cables what happens?
-Because as I can see many photos of gainclones most of gaincloners use normal cable! |
| ukram |
| It is better to use shilded cable. With no shield there can be (capacitive?) pickup from transformer or fluorescent lamps etc. For the same reason it is good idea to use metal case. |
| ashwin |
I have found that using good grounding practice (separate the high level and low level grounds and join them at the star point) and shielded cables result in no hum at all in my gainclones (which aren't in a metal case, BTW). I also found that using a non-shielded cable to the input of my GC from the source resulted in a slight hum, which went away when I used shielded cable. All shields are grounded at one point.
- Ashwin |
| Dxvideo |
I use a metal case for my gainclone and chasis is connected to star gnd. And inside my signal cables are all shielded. But positioning of that cables very important, because when I move closer the shielded cables to the transformer, I heard a 100Hz noise! Shouldnt I use shielded cables inside the metal case? Does it make problem?
And the second question; for preamplifier, if I use the same mains transformer (with the gainclone) the 100Hz noise problem is back again! Now I use another little transformer for it. Does it always happens? Do you use two seperate transformer for gainclone and preamp?
Thanks a lot.. |
| PMA |
| quote: | Originally posted by Dxvideo
Yes, you should use shielded cables. |
| ashwin |
Thanks a lot.. |
This sounds like a ground loop. If the preamp and amp are fed from the same supply, then you need to run only one wire (i.e. the signal wire) from the preamp output to the amp input. Don't run the ground wire in the shielded cable from the preamp output to the amp input.
Hope that makes sense.
- Ashwin |
| Dxvideo |
| Thank you very much... |
