diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Hi Voltage (i'm hom) - Click HERE for Original Thread
Esra Yeknom
How is it that rectifyed voltage can be higher than what is of it expected? Example: my gain clone has psu of 2x25VAC secondary but after rectifyer he is making 39VDC - should be 35.25VDC no? Is it problem with capaciter?
Esra
officeboy
Is there a load on the transformer? If there is not then it will read at a higher voltage.
I get 27V rectified and capped after my 18-0-18 with no load.
tpenguin
You're right. Technically, it should be about 32.5VDC, but just like every other component, transformers have tollerances, and are not exactly the specified value. However, since 30VAC would be necessary to yield 39VDC after rectifying, your transformer would be 20% off, so unless it is a really poor quality transformer, my guess is that it was a 30V+30V secondary transformer that was mislabeled. Check the AC voltage on the transformer taps and see what it is. Also, verify that your multimeter is reading DC voltage correctly by checking a 9V battery with it.
Page generated in 0.018408060073853 seconds with 16 queries,
spending 0.00600624 doing MySQL queries and 0.01240182 doing PHP things.
Copyright ©1999-2009 diyAudio.com
