diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Either of these two transformers workable for a FrankenKlone - Click HERE for Original Thread
Joshua Layne
Hi all,
I've been reading about all of your gainclones - very cool stuff.
As I am a cheap $@*stard. Wondering if any of the following will work?
The shiny copper one I stole from a defunct Philips receiver. It is huge! (33 - 0 - 33 secondaries - no load)
The painted one with all the leads I got somewhere, but I don't remember where. It is a bit smaller and has two secondaries. The first is a 34 VAC (no center tap)
The second is difficult to describe, but taking the first lead as a nominal "zero", it is: (0 - 6.5 - 13 - 25) (so maybe 13 - 6.5 - 0 -12 would be more accurate??)
Anyway, the four-lead secondary is obviously not useful, but what about using an even voltage divider on the 34 VAC leads and tying that to true ground? It would give me a 17 - 0 - 17
I am guessing the Philips is too high of voltage (unfortunate though because it is HEFTY).
Anyway, comments well appreciated - I will probably build one 'right' (with new components), but I need a stereo for the garage anyway, so why not build it 'garage-style'?? :D
Thanks.
j.
Hybrid fourdoor
I think 33V is right up there near the limit of 3886's. Definently need a heat sink for em, but I see 30-35V schematics all over the place.
Joshua Layne
Ok,
Thanks for the reply. I'll give it a try when my chips get here. First round will probably be a rat shack special (although I think I have a rectifier bridge lying around somewhere....)
Now to find some BIG heat sinks.
Rgds.
j.
Page generated in 0.03225302696228 seconds with 17 queries,
spending 0.02101660 doing MySQL queries and 0.01123643 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
