| Aleph 5: resistors, caps, internal wiring? - Click HERE for Original Thread |
| bbakota2000 |
I want to make an Aleph 5. I'm completely new in DIY world so I will probably post a lot of questions here. For starters I have a question about the components that should be used in the amplifier. I saw Mr. Nelson used Dale resistors, and now I would like to know good and bad points of using better resistors (RIKEN). One Dale resistor is $0.40 and Riken is $2.40. Same thing for capacitors. What do I get if I use Black Gate electrolits (220uF)? Or maybe something different. Please tell me your opinion. Let's say I'm not limited with finances and I want the best out of Aleph 5 design. All suggestions are welcome!:confused: |
| roddyama |
| If you do a search on the forum, you'll find a number of threads that will discuss the pros and cons of most of the different components that go into the Alephs and other amps. |
| matjans |
| or you could contact kristijan, check his site , he's in croatia too. |
| moe29 |
the good thing about the Aleph circuits is that you don't need to
build them with exotic parts for them to sound great!
(at least that's my opinion) |
| Magura |
| quote: | Originally posted by moe29
This goes for any of the passdiy constructions....actually a part of the beauty of them :)
Magura |
| Duck-Twacy |
I'm not an expert, but from what I understood (by reading here and there) the most gain comes from a good power supply and being able to increase the bias a bit (requires good cooling).
I myself did use some above average components as well
(caddock power resistores, vishay/dale resistors, big tritec coils, BG caps, BCC elcos, beefy toroid, Kimber wiring and plenty of WBT eye candy), however this makes it a lot more expensive.
Still don't know if it really matters much. |
| Mad_K |
| quote: | Originally posted by Duck-Twacy
Probably doesn't, but it shure feels/looks good and makes us sleep well at night ;) |
| bbakota2000 |
| quote: | Originally posted by Mad_K
I tought so.
I think I got a picture now. I'll just use some mid priced elements. Thanks everyobody for comments. |
| Duck-Twacy |
But I always use a bottle of Cabernet for that
:xeye: |
| Magura |
:xeye: |
By that approach, you actually got something for your money (a bottle of Cabernet ).....as opposed to many others that just got cheated by the marketing machinery. ;)
Cheers
Magura
Edit: the cabernet actually gives you about the same effect when looking at your wife!!! |
| Mad_K |
:xeye: |
Then you are probably sleeping very, very well :D |
