diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
High Power Subwoofer - Jamo SW 505e - Click HERE for Original Thread
EDAT
High Power Jamo SW 505e Subwoofer
Hi, I have for sale a Jamo SW 505e Subwoofer
It was brought it 2001, and has hardly had any use as it is just too powerful. It is in mint condition with absolutely no damage. Here is some of the info from the manufacture:
Active subwoofer with 12" long throw woofer and built-in 100 W amplifier.
The woofer with 6-layer voice coil in a Coupled cavity cabinet delivers a very deep, powerful and well-controlled bass reproduction.
Infinitely variable sensitivity, cut-off frequency and phase settings ensure optimum integration with existing equipment as well as trouble-free placement in the room.
The Coupled Cavity cabinet extends the bass range and also functions as an acoustic band-pass filter with complete control over the diaphragm displacements - even at frequencies far below the audible range - so that the sound will never become unclear or muddy. The result is a bass that you can actually feel in your stomach.
The SW 505E really lays a solid foundation for film sound effects and the bass in stereo music. Dimensions (H x W x D): 435 x 435 x 485 mm. 100 W rated output, RMS. Finish: cherry wood veneer.
Specifications:
Type - JAMO SW 505E
System - Electronic Subwoofer, Coupled Cavity - Bass Reflex
Woofer - 12" / 305mm
Output - 100W RMS
Sensitivity - Adjustable +/- 12db
Frequency Range - 32 - 150Hz
Cut Off Frequency - 70 ..... 150Hz (Adjustable)
Total Volume - 92 l / 3.2 cu.ft
Weight - 21.5kg
The sub cost me £250 in 2001, so I am looking for a price around £110, bearing in mind that this sub is in mint condition and hardly used.
Page generated in 0.018373966217041 seconds with 17 queries,
spending 0.00656891 doing MySQL queries and 0.01180506 doing PHP things.
Copyright ©1999-2009 diyAudio.com
