diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Minimun Components to TDA2030 and TDA1514 - Click HERE for Original Thread
PicancoNet
Can anyone help me ?
abid_rehan
minimum components needed are mentioned in the data shhets of the chips try searching for data sheets an google, however on a personal note I'd suggests consider using something better like LM3886, as these chips wont blow up frequently as TDA 1514 or 2030.
PicancoNet
quote:
In Brazil is so hard to find LM3886.
Because this, i'm using TDA1514.
The Datasheet use many components ?
I want to use the minimun to make the TDA1514 to amplify.
Page generated in 0.023804903030396 seconds with 17 queries,
spending 0.01008677 doing MySQL queries and 0.01371813 doing PHP things.
Copyright ©1999-2009 diyAudio.com
