diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Introductions
Ciao everybody! - Click HERE for Original Thread
seppstefano
Hi all,
nice to be here, and thanks for sharing future infos.
BTW, should you know how to biwire a Dynaudio Contour 1.1, please let me know :-)
Ciao,
Stefano
planet10
quote:
Welcome to the forum...
As to the Dynaaudios, if they are not already set up for bi-wiring/passive bi-amping, then you would need to map out the crossover as a start.
dave
seppstefano
Ciao Dave,
thanks a lot for your kind answer and for such a nice Forum.
The Dyna have only a pair of post and an OCOS cable input.
That's why I'm just looking on the web to get Dyna xover schemas, but it doesn't seem an easy task...
When possibile I'd like to know before opening them :-)
Ciao,
Stefano
planet10
When i get a new set of speakers, opening them up to see what is inside is one of the 1st things i do :^) -- electronics too.
dave
seppstefano
Hi Dave,
"roger", as soon as I open 'em I'll share with you all ;)
Meanwhile, this weekend I'll try to close, drive and "tune" my first shiva based diy sealed sub unit (about 90 lt.), powered with a HK870 and "corrected" by a Behringer DSP.
Ciao,
Stefano
seppstefano
Hi all,
the SUB is sounding preety cool, powered up by a HK/870 and eq'd by a Behringer DSP.
I'm quite happy :)
Now, next steps will be to build the second one, and to open the Dynaudios to check the quality of components.
Do you think that a cap replacement (pgrade) would be worth the effort??
Ciao,
Stefano
Taco
Caps can influence the sound in a possitive way. But changing the coils with lower resistance coils can change the cross-over frequency.
seppstefano
Hi Taco,
thanks a lot for your feedback.
Ok, I would begin with a simple quality upgrade. Do you know which brand of caps Dynaudio use (if common)?
Stefano
Page generated in 0.025737047195435 seconds with 17 queries,
spending 0.00660610 doing MySQL queries and 0.01913095 doing PHP things.
Copyright ©1999-2009 diyAudio.com
