diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
IRF244 for Aleph 5 ? - Click HERE for Original Thread
tcl2
Hello everybody, I'm a newcomer...
I'd like to build an Aleph 5 amp, but I
realized that in France I could not find
the Mosfets required, i.e the IRF244 and
the IRF9610.
Is it possible to replace them by other
Mosfets and which ones ?
Thank you
Nelson Pass
There is a long list of Mosfets which will work. Check out
some of the substitution lists on the Zen articles at
www.passdiy.com
Basically any IR part which resembels the voltage, current,
dissipation, and input capacitance values will probably work
fine.
roddyama
Take a look at this post for a source in Germany at reasonable prices.
Yonnat
Hi tcl2,
I confirm, Reichelt.de is a very good source, cheap prices, they have all you need and it is easy to order trough the net, for the payement the best way is " contre remoursement" called " per nachname" in german because they don't work with credit cards.
If you need some help to do your order or to make your choice I can help you.
Regards.
Yonnat.
Page generated in 0.019288063049316 seconds with 17 queries,
spending 0.00746107 doing MySQL queries and 0.01182699 doing PHP things.
Copyright ©1999-2009 diyAudio.com
