diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Hot follower/cool follower - Click HERE for Original Thread
webercarbmann
Hi
I am wondering if anny of you have build Andrea Cufioli`s Hot and cool follover. In the scematics om his home page some of the parts walues are not there. what should they be? MY_A:confused: Both the hot and cool follower are missing some walues. Hope you can help.
MVH Peter
http://www.geocities.com/ResearchTr.../my/index.html#
HarryHaller
I have built something simular to his Mosfet follower circuit with
Panasonic HFQ caps bypassed by Polypropelyne film caps. It sounded excellent.
H.H.
karellen
I´ve constructed the power follower (andrea ciufoly) with a bride of zen as a voltage amplifier; the sound is excellent, but it seems the heatsinking is a big problem; with 20% more heathsinking capability than the sugested, my amplifier is a little more than 25º C over ambient temp with only 1.3 A bias ( 10 W output)
¿does anybody have the same problem?
thanks in advance
karellen
the two box follower; one for the amp and other for the regulated psu
karellen
the two box
Freddie
karellen,
I've also built a Power follower 99. Mine runs at 2amp, 100W dissipation per channel. I use heatsinks rated 0,34K/W. So heatsink temperature is around 34 degrees above ambient . (0,34*100W).
/Freddie
karellen
the roof off...
karellen
the two box and the missing pic!
karellen
Hi, Freddie!
your comments are very welcome!
so the dissipation I have can be considered normal?
my room temp today is about 27º C and will reach 31ºC ( the summer in Spain)
so your amp will iddle at 61º C...
when mine is over 55º I´ve heard clics and other strange noises,
and I´ve shutted down...
may I ask you to send a picture of your amp?
what are you using as a driver stage?
many thanks in advance
quote:
Originally posted by Freddie
karellen,
/Freddie
Freddie
quote:
so the dissipation I have can be considered normal?my room temp today is about 27º C and will reach 31ºC ( the summer in Spain)
I don't have a picture of my amp (no digital camera). As driver stage I'm using a BoZ running at 100V. It really sounds strange that you heared clicks, and strange noises when the follower get hot. Mine is always really quite. I've been using this follower and BoZ for two years. But now I'm going to replace it..
WT
I have also build the hot follower while drive it with Bride of Zen or tube pre-amp. It sound good and run smoothly. The only problem is it heat. However, now my push pull 300B Amity sound much better.
karellen
Mmmm!
what is a Boz? is the schematic available?
Im not fully sure where the clics came from, but now that I know it can whistand more temp for years, I´ll try to find out.
BTW, I guess your next proyect is Aleph, dont you?
Freddie
quote:
Mmmm!
BoZ= Bride Of Zen
One monoblock is finished, the other monoblock is almost finished, very little work left. My next project is actually another poweramp, check the the "much less crazy idea" if your'e interested. Ohh.. I forgot a new balanaced preamp is under construction too.. So much to do, so little time:)
Page generated in 0.03766393661499 seconds with 17 queries,
spending 0.00978994 doing MySQL queries and 0.02787399 doing PHP things.
Copyright ©1999-2009 diyAudio.com
