diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > ESLs, planars, alternative technologies
Manger....... - Click HERE for Original Thread
tbla
hi,
anyone know where to buy the manger driver....?
mikelm
look here
http://www.manger-msw.com/
email here
info@manger-msw.de
just in case you need it...;)
Nuuk
How do they manage to make the 'Swing' cabinet double walled and yet only a couple of inches deep? I though that it was an open baffle at first!
tbla
quote:
open baffle
isn't the manger driver a "closed system".......?
tbla
i think somebody once told me that manger had stopped selling the drivers seperatly.....?
Pan2
The manger driver in itelf is not a "closed driver". It is normally used in a closed box though as most dynamic midranges.
The Mangers was away for a while but are now selled to DIY´ers again I believe.
/Peter
Nuuk
But look at the pictures of their enclosure. It is only a couple of inches deep. :eek:
Pan2
The "Swift" was news to me, had a look at it and thin it is :).
I don´t know but I guess it´s just a shallow box.
/Peter
Stixx
The box is very shallow but gives ample volume for the driver.....it just needs about 15 liters or less (closed of course) . It is highpass filtered at around 180 Hz, for the lows you have to use a (their) sub.
I think they are selling individual drivers again since even on german Ebay I have seen them selling "B"-drivers (with very minor aesthetic flaws).
Tschuss,
Oliver;)
Petter
According to Daniela Manger, they driver units function optimally at about 10 litres of volume. I have played with the drivers (loose) and can also attest to the fact that they are VERY sensitive to what is behind them.
The drivers are very interesting - and by the way if you come across a pair, you know if they are the most recent versions (as of a year ago at least) if they have many small coin sized magnets instead of traditional ring ferrite.
The drivers themselves have a weak point (if mishandled) which is the 4 wires woven into the diapghragm - particularly the ends seem to be fragile to certain finger-pointing-touching individuals. Make sure they are not damaged or you will have to send the drivers back for an expensive rebuild. Trying to fix this at home will cause the drivers to look suboptimal and likely perform subotiomally in a big way.
Petter
Page generated in 0.026705980300903 seconds with 17 queries,
spending 0.00837803 doing MySQL queries and 0.01832795 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
