diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Bias current - Click HERE for Original Thread
peter5
I just turned on my leach amp to set the bias current but turning the potentiometer didn't do anything. The current was stuck at around 20 ma. Can anybody tell me what's going on?
Thanks.
Peter
serosmaness
Hello It seems that I may have a problem with adjusting the bias current. The bias current stays around 19 to 25 ma. Please help.
Serosmaness
ACD
Most problems with bias current adjustment are caused by the potentiometer........ Carefully try to meassure the output of the potentiometer and check that it actually variates the voltage to the base of the Bias transistor;)
serosmaness
Thanks Jan for the reply.I changed the pot and checked on the board for change of resistance. Everything checked good.
I put a squarewave on the input and got a amplified output but it was not clean.
The good channel is biased to 115 ma and works but its response is notably different than my Sumo. Less bass.
Thanks Serosmaness
ACD
Did you check for a defect bias transistor ???
serosmaness
Thanks again Jan for your response. I found the problem. I swapped the B and E on the output transistors. I biases fine now.
Thanks again
Serosmaness
ACD
Ok ;) Then happy Amp'ing....:D
Page generated in 0.019505977630615 seconds with 16 queries,
spending 0.00721741 doing MySQL queries and 0.01228857 doing PHP things.
Copyright ©1999-2009 diyAudio.com
