hi i need a pin out diagraim for a sharp qa -1050 i have found a diagriam for a sharp qa-1150 do these panels use the same cable
thanks alot
golftdibrad
i'm pretty sure all the sharp panels use the same cable.
I used a cable from a 1050 and it worked on a 1000 and a 1500
Brad
Neo
thanks alot i thought the cable would be different for a 1050 but i have a cable for a 1000 , 75 which i got ofebay so ur saying that it should work with the panel
Page generated in 0.030076026916504 seconds with 16 queries, spending 0.02141213 doing MySQL queries and 0.00866389 doing PHP things.
