diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Leach amp w/o feedback - Click HERE for Original Thread
Musher
Would there be any idea in using Leach amp without feedack? I know it'd increase THD, but to counter that I could match all stages. I think some version was quoted as having 1% THD at 50W without feedback. And if that's lower with less power, I might as well give it a try.
-Kimmo Sundqvist
ppl
How would you then define the Closed Loop Gain? would you also Reduce the Amps Origenal Openloop gain? I have used a Multiloop Feedback on the Leach Amp by applying a resistor from each side of the Voltage gains second stage to the Inverting input. Also the output stage is feed back to thie inverting input. The Open loop vs closed loop gain of the amp can now be easly controled. Other methods of reducing the Openloop gain include larger Emmiter resistors on eather the First Diff Amp or the Second Gain stage. Exparamentation in encouraged like i have also operated the output stage only Outside the Feedback Loop with the Feedback still taken from the Voltage gain stages as in the multiloop method. Anyway yave fun with this because you can the Possibilities are endless.
Page generated in 0.016284942626953 seconds with 16 queries,
spending 0.00768995 doing MySQL queries and 0.00859499 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
