diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
BoSoZ with CCS -- need sugestion... - Click HERE for Original Thread
sianturi
I am planning to build BoSoZ to drive Aleph-X. But since I don't have balance source, I'm going to operate the bosoz unbalanced-in to balanced-out. So, to keep the Vout+ and Vout- equal in magnitude, I replace R3-R6 with CCS. Iref and Iconst were set to be around 40mV, with Iref = 0.67V/R75.
With R75 = 17, Iconst (=Iref) will be approximately 39.4 mA.
I attached the simm result here, and we can see that the CCS works nicely, so that Vout+ = Vout-. The simm shows the Iref = 41.912mA, and Iconst= 41.962mA.
I run the simm with only one souce (Vs) because I wanted to operate it unbalanced in.
Any sugestion/mods to this circuit? The simm looks OK, but I don't know the result in the real world.
One thing weird about this circuit. I run the simm on Protel DXP, and each time I changed the value of R75 & R76 to, say, 17.5 ohms, the Vout and Iconst swings hecticly. At first, I thought that this circuit was not stable. But, I notice, when I change the value of R75/76 other than 17 ohms, the simm displays a warning: "Gmin stepping failed." What does this mean? I have already change the Gmin parameter before running the simms. Btw, what is Gmin parameter? :confused:
Thx folks!
sianturi
I forgot to mention. I run the Vs = 20 mV @ 1kHz. Actually, what is the typical magnitude of input voltage to a preamp?
Nelson Pass
Assuming that Iref and Iconst are just measurement
points for your simulator, it looks fine.
Z3 and Z4 are superfluous, and there is no need for the
negative supply rail to be so high. 20 volts would be more
than enough. Also you could consolidate the current sources
of Q3 and Q4 into 1 current source, feeding each Source 62
ohms.
Also the negative input should be grounded, so short R14,
the 100K resistor to ground.
Everytime I look, I see something else..... ;)
eLarson
quote:
I have one like your schematic (sometimes I used a balanced input, sometimes not, so I kept circuitry around the - input).
I've been extremely pleased with the sound using either a single-ended tuner or a balanced D/A converter.
Erik
jh6you
ohms.
I see.
I have thought that two sources, however, could provide us with more convenient advanture for gain adjustment, if wanted.
Happy New Year!
Nelson Pass
quote:
The SOZ schematic shows a topology which allows some
adjustment with only one pot. You might consider something
like it.
sianturi
ohms.
VOILA!! I have already thought of the possibility of using 1 CCS instead of 2, but it never occured to me that the answer is splitting the R15 into 2 x 62ohms. :smash: Thanks a lot Mr. Pass!
So here it is, the BoSoZ with one CCS.
A few notes about this circuit. I set R75 = 7.5 and R77 = 100K, so that the value of the Iconst = 80mA (trial and error in simm). Why I pick this number? Cause it is a standard resistor value. I could set the R77 = 15K but then, the R77 has to be 8.375 ohms (non-standard value) in order for Iconst to be 80mA. Is 100K for R77 too big? Is it ok to set it to 100K? :confsed:
I leave the Z3 and Z4 attached for future use if I have a balanced source.
I also use -60Vdc because I plan to use just one transformers (+55V and -55V tap transformer)
I hate it when you have that kind of smile....
Another improvement?? :scratch
sianturi
The simm result (one CCS)
sianturi
Oooh, again....
Need comments. Especially the value of R77 (100K).
Thx!
nobody special
The only thing to remember is that any resistance between the sources of the differential pair will mess up the symmetry of the outputs. You could get rid of the resistors completely, but then you have to find a way to get rid of all the extra gain. Kind of a catch 22 situation, unless you use feedback (which could be cool, because you could apply susy to the circuit).
sianturi
quote:
Btw, SuSy = Aleph CCS, or Susy = X feedback?
I have a thought about applying aleph ccs to this circuit. But I first have to read carefully Mr. Pass' patent about this. I guess this is what the Nelson's smile is all about.... :scratch:
nobody special
SuSy= X feedback
Here's what I have in mind:
eLarson
Are you saying that any MISMATCH between the resistors used for source degeneration would 'mess up the symmetry of the outputs'? Or the presence of source resistors in general? Source degeneration is, itself, a form of local feedback.
I'm still not sure if it would lead to "super-symmetry" or just "so-so-symmetry", however.
eL
nobody special
The presence of them in general...
when driven with a single input and using a balanced output, ideally you should have the sources joined together.
As far as the symmetry of it is concerned, I agree it's not perfect, but the results are better than with the sources coupled through a resistor.
jh6you
The SOZ schematic shows a topology ...
Thanks. Too often my thinking loses flexibility. :cool:
sianturi
SuSy= X feedback
Actually, I have already thought about X-ing this circuit
I have already look at Henrik's X-BoSoZ circuit, and even made a PCB tracks for it (with double CCS). Actually, what I have now is a PCB track which can be used as regular Bosoz (without CCS), Henrik X-BosoZ, and Bosoz with (double) CCS. :cool:
To say it in english, regular Bosoz + Bosoz double CCS + Henrik XBosoz in one PCB, so that I can experiment several config.
I guess I just have to rework the PCB....
sianturi
And the circuit....
kristijan-k
Hello,
A few months ago, my friend and I also started thinking of
useing CCS in BOSOZ preamplifier, and here below is with
what I come up.
This one is heavily biased, and it would nead for shure larger
heatsink than original BOSOZ.
It is biased at 300 mA per each rail, and is dissipateing 35 W
of heat per channel.
Best regards,
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
eLarson
What's the mechanism for the degradation, though? I'd have thought that the output impedance of the constant current source would dominate things...
eL
sianturi
Hmmh.... This one I don't understand also.
Is it because of the presence of the resistor, would destroy the same voltage characteristic between the source of Q1 & Q2 mosfet?
Nelson Pass
As a concept, you cannot eliminate resistance between the
Sources, as the transconductance of the devices themselves
gives rise to an apparent resistance. Resistance placed
between the Sources lowers the open loop gain of the circuit.
nobody special
Well, when Nelson speaks, I shut up and listen. :D
sorry for the misinformation.
Adams_Leo
Hi Mr.Pass,
You mean we must keep the resistors R3 and R4,right?
thanks
Leo
Nelson Pass
No, you don't have to keep them, but the gain might be higher
than you want, and matching becomes more important.
GRollins
R3 and R4 serve to degenerate the MOSFETs in the differential. Depending on your frame of mind, you can choose to regard this as feedback...or not...whichever suits your mood. The IRF MOSFETs have very high transconductance compared to something like the 2SK170 or the 2SK246. In principle, you can re-fiddle the circuit to offset that gain. One way to do so would be to lower the value of the load resistors--but then you have to increase the bias in order to assure something approaching equal voltage swing. That increased bias will mean more dissipation in the load resistors, which is in turn offset somewhat by the lower resistance. You may need more robust load resistors to handle the heat (I haven't done any calculations--this is all seat of my pants). The load on the power supply is also increased, which could lead to a bigger transformer. Then your parts cost increases. And so on and so on. In other words, it's all a balancing act. Nelson has chosen a balance that works well for him, but you could very well get crazy and use some of those aluminum body power resistors, put heavy heatsinks on the MOSFETs, throw a monster power supply into the mix, and end up with a very different flavor from the stock circuit.
Me? I kinda like the idea of lower resistance loads, which in turn gives you wider bandwidth, but nothing is free and you'll have to be careful about just throwing random parts into the circuit without watching the thing on a scope to make sure that you haven't shot yourself in the foot. Something I do every so often, just to keep myself humble.
(Humble? Oh dear Gussie, the boy is gonna get zorched by a lightning bolt for saying that.)
Okay, how about I say it keeps me from getting too far ahead of myself?
(I suddenly feel kinda prickly all over. Didn't I read somewhere that just before lightning strikes, you feel like you've got ants crawling all over y--
jupiterjune
I am using a dual-pot (500 ohms) in conjunction with R3 and R4 (10 ohms each). It makes an effective gain adjustment for the modified BOSOZ circuit.
JJ
Adams_Leo
Due to Chinese Spring Festival,I have taken long vacation and have gone my home town.
Gery and Pass,thanks for you full explain.I have the IRF610 in my hand,so I will try it first.But the SK170 in my next plan.
Leo.
Adams_Leo
quote:
Originally posted by GRollins
R3 and R4 serve to degenerate the MOSFETs in the differential. ....
Hi Grey,Another a stupid question.Could you tell me how to calculate the circuitry input/output impedance which in post#26.
thanks.
Leo
Page generated in 0.070069074630737 seconds with 17 queries,
spending 0.00911975 doing MySQL queries and 0.06094933 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
