| adrianvanourti |
I want to make my own DIY projector and I can buy a new touchsreen of 12" for 180 EUR...
Now my question can you see if the specs of the screen are good?
Thx
Adrian
Specs:
Modul Typ. / Modul Art Colour Active Dot Matrix TFT Module
Display Size / Displaygröße 12,1" / 30,7 cm
Active Area / Bildgröße Horizontal 259.0 mm
Vertikal 287.2 mm
Resolution / Auflösung 800 x 600 (SVGA)
Horizontal Frequency / Horizontal
Frequenz
24~69 kHz
Vertical Frequency / Vertikal Frequenz 50~85 kHz
Input RGB Signal / Eingangsignal RGB - Video: Analog 0,7 Vss
Seperate Sync.: TTL pos. / pos.
VGA Standard-Input: D-Sub 15pol.
Digital Input Nicht lieferbar
Input Video Signal / Videosignal optional auf Anfrage,
S-VHS (4pin-Mini-DIN) und FBAS (Cinch)
Contrast Ratio / Kontrastverhältnis 150 : 1 typ.
Backlight / Hintergruntbeleuchtung 2 x CCFL, MTBF: 10.000 h
Brightness / Helligkeit 150 cd / m² typ.
Viewing Angle / Betrachtungswinkel Horizontal 90°
Vertikal 40°
Number of Colours / Farbtiefe 262144 (6 bits per RGB sub pixel)
Power Supply / Netzteil ext. Power supply, Input 100 - 240V AC, 50/60 Hz Output 12V DC
Chassis Dimensions /
Chassis-Abmessungen
303 x 239 x 37 mm
(W x H x D)
Weight / Gewicht approx. 2,5 kg
Temperature Range / Temperaturbereich Operating / Betrieb 0° to +35° C
Storage / Lagerung -20° to + 60° C
Shock / Schock Storage / Lagerung 35G, 11ms/direction
11ms/Richtung
Vibration / Vibration Storage / Lagerung 1,5G , 10-200Hz, 30min/cycle;
x,y,z each one cycle
x,y,z jeweils 1 Zyklus |
| Takusama |
| quote: | | Contrast Ratio / Kontrastverhältnis 150 : 1 typ |
You don't want it. :whazzat: |
| adrianvanourti |
I don't have much money so I want to build a projector as best as possible for a resonable amount of money. The LCD screen only costs 165EUR :D
If the contrast ratio is small (1:150), the projecton will be dark?
Will the quality be accepetable? |
| 18wheeler |
it wont be dark but it will lack details, has less vivid color. If you use strong light, it will appear to be washout.
by the way, will you sell me the touch panel if you remove it from LCD? I am building a computer for my 2-year-old. He always compete the computer with me. the screen is covered with his fingerprints. |
