| ...and so it begins - Click HERE for Original Thread |
| ace3000_1 |
Heya buddy, what parts have u already got and havnt got? cos the projection lens is the wrong one and wont work, also that lcd cant be used for projection cos its a panasonic lcd and has ribbon cables that are in the way, also the 400w mh is far too big for such a small screen, a 250w hqi should be used at the most cos of heat and guiding the light through the lcd, hope it helped buddy.
Trev |
| Lori |
| I hope you aren't thinking too small. That ballast, bulb and socket are going to require a pretty large area. |
| sp33dl0v3 |
| quote: | Originally posted by ace3000_1
Trev |
heheh thanks for the reply
this why i posted first :D
i knew i was gonna be getting something wrong
revised the list
http://www.1000bulbs.com/product.php?product=923
MH250/480v ballast
$39.99
http://www.1000bulbs.com/product.php?product=548
MH250/U/CL/MOG bulb
$14.84 each
http://www.surplusshed.com/pages/item/l3003.html
FUJINON COPY LENS, 240MM FL
$11.00
http://cgi.ebay.com/ws/eBayISAPI.dl...8&category=3698
Slim 7" VGA / PC / AV TFT LCD Monitor
$235.00
this is the stuff i already have laying around
4 mirrors both glass and polished aluminum in varing sizes 6"square (glass), 10"x 8"(glass) , 2 8" x 8"(aluminum).
3 pc fans
12 volt power supply
still undecided on what to make the case out of...a friend of mine does vacume plastic molds...so i might try that route.
the other stuff i'm gonna pick up at american science and surplus(http://www.sciplus.com/)...they have a store local here in chicago. |
| EasyPrey |
Where are you going to get 480v here, in USA, if I may ask? I'm either missing something important about this country or you better try preassembled 110v ballast/ignitor with such a level of electricity knowledge. That's the I'm going to get from them actually - hence can't say for sure if that's what we actually need ;)
You'll need mogul socket for your bulb too I beleive. |
| MovLab |
Hi: The Primary is a Multitap at
120/208/240/277.
Just An Fyi..
MovLab :)
USA Here Too...
| quote: | Originally posted by EasyPrey
| EasyPrey |
| quote: | Originally posted by MovLab
120/208/240/277.
You mean in the product captioning 'MH250/480v ballast' 480v doesn't mean voltage? God, then that guys at 1000bulb _are_ weird :smash: |
