diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
M108 vs M59 - Click HERE for Original Thread
brainchild
Anyone seen an M108 ballast? I can't even find one for sale. There's a double ended 400watt MH bulb I'd like to get and it specifies an M108 over the M59. I'm guessing the diff might be the starter...
Any ideas?
tesla500
I believe this is what you need. I've searched high and low for an M108 ballast, but this was the closest thing I could find. It's pricy at $160, but a 400 watt HQI metal halide with a proper reflector and condensor lens will make for a very bright projector, maybe 1000-1500 lumens.
Bulbs to go with this ballast can be found here. I think they use ths same sockets as the 250W HQI.
David
Mr.Kh
Yeah I haven't looked too much locally, but online it seems like mostly electronic ballasts in that range (M108, and M102 etc) it could be a starter issue - which would account for the lack of magnetic ballasts. Not sure though.
Welcome to the forums Tesla, good to see another fellow West coast Canadian.
Page generated in 0.027295112609863 seconds with 17 queries,
spending 0.01609349 doing MySQL queries and 0.01120162 doing PHP things.
Copyright ©1999-2009 diyAudio.com
