diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Lvds motherboard and Laptop screen - Click HERE for Original Thread
dracul
I have an oportunity to buy this from a local auction here in argentina? http://www.logicsupply.com/product_...products_id/138
I am looking on ebay for nice high rez laptop screen i can use to work with it. Does anyone know what i should look for? I found inspiron 7000 screen cheap but cant find out it it will work or has lvds interface. If an screen had lvds interface will I still need a lvds receiver or some other card? I ask because I noticed all laptop screen seem to have a strange ribbon cable only and nothing that looks like you can just plug in an lvds cable from the motherboard.
The auction ends soon for things. Please help me.
Wes Marquenie
It's not fast enough for mpeg 4.
0320400
Ohoh,
Think there's a mistake here...
Sure it will be more than fast enough for Mpeg4...
(not good at all for gaming, but movies.. OK)
But, I'm not sure about the LVDS to use with your laptop screen...
Wish ya luck
Wes Marquenie
A 600MHz Via Eden isn's as fast as you might think. It's like a 300MHz Intel PII
0320400
Ok, you might be right with your comparison
but, I play Mpeg 4 on my PII 333 under WIN98 with just 128 Mb of ram (and a Geforce4MX, but that doesn't really matter i think)...
So normally it isn't a problem...
freeupyermind
whats the max rez this thing can handle?
Khmann002
It will work fine, if it doesnt support the divx playback then you can get hardware decoders now for divx!!
Khmann002
Hey just to add to my post above. Why dont you just avoid the whole problem and get a better board. Why take the risk of having to buy a decoder for $40-$60. Look at this ....http://www.ewiz.com/detail.php?p=MB-E-M1GXL&c=pw and it has the lvds! And it even had surround sound and all. nice
freeupyermind
BUT WUT IS THE MAXIMUM NATIVE RESOLUTION (ON THE LCD) IT CAN HANDLE?
dracul
Here is another link to the same board with the rez spec.
Bad news.
http://www.leadman.com/products/ite...AM1L&DROPSHIP=N
vudutek
quote:
http://www.viavpsd.com/product/3/4/EPIA-M_v1.40.pdf
from pg 46:
Panel Type
This setting refers to the native resolution of the display being used with the
system. Settings: 1600x1200, 1400.1050, 1280,1024, 1280x768,1024x768, 800x600
and 640x480
Hope that helps.
/edit: Dracul, that only states 1024 x 768 for TV out....
dracul
I thought of that but then I figured why would they mention 1024x768 for tv out. Tvs cant display that kind of res can they or cant benefit from it anyway. Maybe they ment hd tvs?
Ok so what laptop screens can we hook up to this thing right out of the box?
Page generated in 0.052130937576294 seconds with 17 queries,
spending 0.02901077 doing MySQL queries and 0.02312016 doing PHP things.
Copyright ©1999-2009 diyAudio.com
