diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
InFocus 640fx specs - Click HERE for Original Thread
MrPoopy
I'm having trouble finding specs for this panel. I've looked everwhere and haven't come up with anything. I also searched this forum and didn't come up with anything.
If anyone has the specs, I would appreciate it.
MrPoopy
I just aquired the specs from a tech support person at InFocus.
I usually consult the panel database at members.cox.net/rolm but there was no info for that panel.
I believe the person that maintains the members.cox.net/rolm site is a user of this forum, so incase that user would like to update the database with the info, here it is:
InFocus 640fx
640x480, passive matrix, 64 colors (that's what the tech support guy said, I don't know what bit 64 colors would be).
msx-2
2*2*2*2*2*2=64 so 2^6=6 bit color
Otiman
it could be 64 thousand colours
ie. 16bit
2^16 = 65536
Otiman
edit: I've been told they can have up to 4913 colours, and 64 colours is for "business mode" or something. Suffice to say that that many colours *should* be ok for dvd/video playback, but if i were you i'd want to see it in action before purchase.
msx-2
if it is a passive matrix panel , as you say, you can forget it. There will be enormous amounts of ghosting,so video won't work.This panel is worth virtually nothing if it is a passive one.
NeilKishar
hi there!
I get one projector, but i dont have a power supply for him, from which voltage is it working?(i dont know is it working or not...)
Some schematics for this panel?
Thanks!
v1d9uy
if its 4000 colors theres no way id use it ... even 64 thousand i wouldnt use nothing less then 256 thousand .....maybe ...
Page generated in 0.23963189125061 seconds with 16 queries,
spending 0.17107058 doing MySQL queries and 0.06856132 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
