diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Will this anamorphic lens work? - Click HERE for Original Thread
dracul
Will this work with a 15 inch lcd?
wout
this is like making a picture of a walkman and ask what songs are on the tape :P ;)
you need to say where you have it from, focal length, diameter, and anything else that may be printed on the lens it self
dracul
ok.
Moeller Anamorphot 32/2x cinemascope 1 inch thread diameter.
One inch back diameter. No way that will work will it?
kcsabresfan
So what songs were on the tape?
Da5id4Vz
Cinema scope w/ optical sound usually was shot with an aspect ratio of 2.55:1.
16x9 video is closer to 1.85:1
4x3 video is something like 1.33:1
If you can find a way of getting the lens into the optical path, chances are it would make everything too short and too fat.
There were typically two flavors of these lenses, some threaded on over the normal projection lens, others were used as replacements for the normal projection lens.
With a 1-inch thread diameter it sounds like your lens is for use with a 16mm projector.
Page generated in 0.031032085418701 seconds with 16 queries,
spending 0.01965380 doing MySQL queries and 0.01137829 doing PHP things.
Copyright ©1999-2009 diyAudio.com
