diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Question upgrading lumens - Click HERE for Original Thread
javi6543
I´ve read in the forum that the overhead projector should be 4.000 lumen aprox. por good results, my question is, if i get an OHP with less lumens, can i upgrade it changing with more powerfull bulbs? or did it crash it? Should i change the fan too? Thanks in advance.
hakkukakt
yes you can, but pehaps you must doing little adaptation for your new light...
1. depend Voltage and Power of new light
2. Hallogen or HQI => HQI need ballast
3. yes pehaps you need mount a more big fan (but you need test for saying)
good luck
javi6543
the question is that in spain is a little difficult to find an OHP, i have foud one of 2500 lumens, exactly a kindermann with 2 halogen lamp 400 watt, and i would know if i could install a MHC150/U/M/4K Light Bulb which has more life hours.
Is it possible? What is a ballast??, i've read a threat about create an own ballast, but i don't understand what is it used for.
Could you help me please, i would be very pleased.
hakkukakt
hi
a ballast is for doing a high voltage for ligh style HQI (the same system for neon light)
but a 400 W halogen is more suffisent for start a diy projector and doing test :D
Page generated in 0.047544956207275 seconds with 16 queries,
spending 0.02934861 doing MySQL queries and 0.01819634 doing PHP things.
Copyright ©1999-2009 diyAudio.com
