diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Condenser height... - Click HERE for Original Thread
chasse
I did built a light engine and i tested it.I use a mh 175 watt with a refflector and 60 mm condenser.I will use it with a 7 inchs LCD.
The beam is not wide enough to cover the entire 7 inchs rectangular cardboard at 6.2 inchs distance that i use to test. I found a 7 inchs fresnel with 6.22 fl but want to know if i can use it before i buy it .
This is a bi-convex condenser and the light bulb is touching it.
Does a bigger condenser,say 70 mm, will enlarge the beam of light enough to cover the back frensel.
Does a plano-convex condenser give a wider beam at short distance.
Page generated in 0.036181926727295 seconds with 16 queries,
spending 0.02482247 doing MySQL queries and 0.01135945 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
