diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Gamut amplifier - Click HERE for Original Thread
jouch
I'm wondering I some body have some informations about Gamut amplifier.
The construction and circuit seem to be realy easy, they only use two mosfet per channel.
But that's all I know.
Christopher
leroy
All I know is that high power MOSFET's modules in a so-called Mini-Bloc (SOT-277) package are used.
The schematic would be rather similar to an upscaled aleph or so, I think...
jouch
So I suppose I should use the same architecture as one an Aleph, but change the out put stage with this block?
Christopher
Nelson Pass
Certainly you can give it a try. I have built some
Alephs and Zens with the IR TO-240A packages,
and the 500 watt rating is certainly attractive. They
consist of 4 regular sized power chips arranged in
parallel or series/parallel depending on the part.
However...
These are 10 times more expensive than a single
device at 200 watts, which while not a consideration
for me, (mine were samples) will not be ignored by
most everybody else.
and...
You cannot assume the level of matching of the
parts as it appears that they are intended for
switching applications, where Vgs matching is
not so important.
nevertheless.....
These are cool looking industrial parts, and you'll
be the envy of all your DIY buddies. :)
lohk
What about the Greenwall amplifiers ?
They look like a complete ZEN family ripoff.
reinhard
Hallo,
had a close look at the greenwall amps. They are Zen Amps. Look at www.greenwall.de
Reinhard
Nelson Pass
They aren't the first. A certain outfit in
North Carolina also plagiarized the Zen.
HarryHaller
And they even have a link to Passlabs on thier site!
H.H.
Page generated in 0.030320882797241 seconds with 17 queries,
spending 0.00962782 doing MySQL queries and 0.02069306 doing PHP things.
Copyright ©1999-2009 diyAudio.com
