| Batterie powerd Pearl, Questions - Click HERE for Original Thread |
| Dr. ODD |
Hi All
I want to build a Batterie powerd Pearl with lead Batteries and I am not shure at 3 Points
1) I want to bring Power in before C15. I could give 30V by using 6V Batteries but it would be easyer to give 36 V ( I would like to use 12V Batteries because it is easyer to find chargers for them, and 24V cold be a littel low as I read in a former Thread). Higher ratet caps would be no Problem.
Do you think I would blow something else whith the higer voltage ??
2) I cold give a second Voltage of 24 V before C8 and get rid of the regulation circut around Q 3. Do you think this would be an advantage ??
3) Could the combination of 1)and 2) bring some Problems ?? |
| Panelhead |
| quote: | Originally posted by Dr. ODD
Hi All
The small problem is that most 12 volt batteries output 13.2 volts. Three would give something like 39.6 volts at the power level seen in the Pearl.
The two in series should put out 26.4 volts. This is usable if bypassing the first regulator. With batteries the regulator should be fine. Keep the second regulator. The input stage needs very clean power.
George |
| Dr. ODD |
Thank you George
I wanted to get rid of the second regulater because I thought the Power would be cleaner and faster if it comes directly from the Batteries (of course via a few caps):angel: :angel: :angel:
Bernhard |
| akb1212 |
Thank you George
Bernhard |
There should be no need for the regulators if using only batteries no :)
For more detail on how to charge take a look at my post here: http://diyaudio.com/forums/showthre...9502#post289502
By following the simple guidance’s given it should be easy to make your own charger that could be part of the system. You could have a switch to go from charging (and possibly using while charging if constant voltage charging) to battery use.
This is the way I'm going for. The only problem is that this way of charging is much slower. But the upside is that you can use the regulators in the circuit (you just scale the regulators to be able to take the charging currents, but at constant voltage these are rather low, thus also the long charging times), and you can even use the amp (or whatever) while charging if needed.
There are also charger regulator chips available that is possible to use on other voltages than 12V. You just have to do some searching.....
Anders |
| johnferrier |
| quote: | Originally posted by akb1212
I'm interested in a battery powered amplifier and wonder about using batteries without regulators.
Is it a problem for this type of amplifier if the discharge rate differs on the + and - rails? What if the voltages don't track?
For the Pearl amplifier, does a 1 volt difference on the + and - rails cause a DC offset?
JF |
| Dr. ODD |
| quote: | Originally posted by johnferrier
JF |
The Pearl does not have + and - rails, just + and ground . So this Problem can not appear:)
(I dont know whats about in other amps) |
| joho |
Thank you George
Bernhard |
Hello Bernhard,
One remark, battery power is clean but slow and sounds dull. The only solution is a buffer with large caps(40000uF min.). Take as much as you can get(and afford).
Take HQ capacitors like the BC154-series.
Only then,your amp starts singing !
Johan.:smash: |
| Dr. ODD |
Thank you for the manny usefull hints
but could anybody come back to my first asked Questions ?:spin: :spin: :spin: |
| joho |
Hi Bernhard,
You can put 3x13=39V battery power at C15 if you like but don't kick out the second regulator ,that's a realy important one(as mentioned before in this thread.
I think the circuit is not very critical but it's better to make R13 and R14 a little higher. All the expected voltages are notated in the schematics so it's a peace of cake.
By the way,bypassing regulation circuits is not a garanty for better sound quality. In fact you must build both and listen for differences.
Did you already look at the Aleph_ono phono amp ?
That's top of the bill.
Johan. |
| Dr. ODD |
Thank you Johan,
yes I had a look on the ono but it seemed to me much more complicated than the Pearl.:bawling:
I think I would not be abel to build the Pcb:bawling:
Maybe if the ono Pcb group buy which is planned happens I will try it:) :) :)
But I think building the Pearl should be great anyway:) lots of People in the Forum seemt to be verry happy whith it.:) :) :)
At the moment I think it is better to build a Pearl then to plan a ono:D :D :D
Kind Regards
Bernhard
Ps: I love those Smilies:clown: :clown: :clown: |
| joho |
Thank you Johan,
Kind Regards
Bernhard
Hi Bernhard,
Your last 3 smilies have a red nose ,did they drink to much ?
Only tomorrow is allowed to get dronk.
By the way,when you are a starter the pearl is a very good choise
and also the rest of your set (cartridge,turntable,amp etc.)is very important if a ono has any sense.
When you want to develop a print layout please look at the "Eagle"site. You can download some freeware and it works fine.
Best regards,
Johan. |
